installation Petsc 3.0.0 and parmetis
Tue May 5 15:37:24 CDT 2009
    This function is defined in libmetis.a but used by functions in
libparmetis.a
    Likely the applications make file doesn't properly list -lparmetis
-lmetis like it needs too?
    If this is not the problem then do (in the PETSc directory) nm -o
$PETSC_ARCH/lib/lib*.a | grep METIS_mCPartGraphRecursive2
and send us the results.
    Barry
On May 5, 2009, at 9:48 AM, Fredrik Bengzon wrote:
> Hi Petsc team
> I've installed petsc 3.0.0 with parmetis for use with superlu_dist.
> Everything compiles well, but when I link with my application code I
> get undefined reference to METIS_mCPartGraphRecursive2. Do I need to
> set any LD paths or something pointing to the 'externalpackages'
> directory or should this be taken care of by Petsc?
> Regards,
> Fredrik Bengzon
