Cast matrix as a vector?
Sun May 3 12:16:12 CDT 2009
1) I guarantee you the copy takes no time. Measure it.
2) If you are worried about memory, PETSc Vec and dense
     matrix can have the same layout and share a pointer.
  Matt
On Sun, May 3, 2009 at 4:42 AM, liu chang <liuchangjohn at gmail.com> wrote:
> I'm using TAO's LMVM method for optimize a dense matrix, but TAO
> expects its input as a Vec. Do I have to copy the content back and
> forth between a Mat and a Vec? Can I somehow cast the Mat into a Vec?
> Both the Mat and the Vec are distributed evenly across the processes
> so ideally there doesn't need to be any copying at all.
> Thanks,
> Liu Chang
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090503/ecda74b4/attachment.htm>
