no parallel speedup with slepc krylovschur
Jose E. Roman jroman at dsic.upv.es
Tue Jun 30 09:36:12 CDT 2009
On 30/06/2009, Christian May wrote:
> Dear readers,
> I want to solve the following generalized eigenvalue problem in
> parallel:
> http://www.phys.ethz.ch/~cmay/binaryoutput.tgz
> (gnu zipped tar of the binaryoutput you get using -eps_view_binary)
> I know the approximate value of the lowest eigenvalues I'm
> interested in, so I'm using shift-and-invert with the following
> options:
> -eps_type krylovschur -st_type sinvert -st_shift -0.228 -eps_ncv 32 -
> eps_nev 16 -eps_tol 1e-10
> However, when I use multiple CPUs, I cannot see any speedup. I am
> not sure whether this is a problem of the matrix or of my system.
> Can anybody please have a look?
> Thanks
> Christian
With a shift-and-invert scheme, most of the computing time is spent in
the solution of linear systems. In SLEPc 3.0.0 the default is to use
KSP=redundant+PC=lu for the linear systems, so it is normal that you
get little or no speedup with more than one processor. You should
either use a truly parallel direct linear solver or an iterative
linear solver. Please contact the SLEPc team directly if you need
further assistance.
Best regards,
Jose
