mpiexec
Yixun Liu enjoywm at cs.wm.edu
Thu Jun 25 13:30:41 CDT 2009
My PETSc based application can work correctly, but after system updating
when I use the same commands:
>lamboot
>mpiexec -np 4 application
It seems only one processor works. Then I  test it using the following code,
PetscErrorCode ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
 COUT << "This is processor : " << rank << ENDL;
Use command: mpiexec -np 4 application,
The output is:
This is processor : 0
Thanks for your help.
Yixun
