fortran 90 program with PETSc
tsjb00 tsjb00 at hotmail.com
Wed Jun 24 17:59:06 CDT 2009
Many thanks for your help! I've tried the method in your email .
In the main program called driver.F, it is coded:
      program main
      use parm
#include "finclude/petsc.h"
      implicit real*8 (a-h,o-z)
I got the following error information :
 In file driver.F:280
      implicit none
        1
 In file /home/jinbei/Soft/petsc-3.0.0-p5/include/finclude/petsc.h:209
     Included at driver.F:279
                   2
Error: IMPLICIT NONE statement at (1) cannot follow data declaration statement at (2)
Would you please tell me what might be wrong?
Many thanks in advance!
> Date: Wed, 24 Jun 2009 16:59:43 -0500
> From: balay at mcs.anl.gov
> To: petsc-users at mcs.anl.gov
> Subject: Re: fortran 90 program with PETSc
> On Wed, 24 Jun 2009, tsjb00 wrote:
> > Hi!
> >  I am trying to parallelize a fortran 90 program with PETSc. The
> > original program uses a lot of global variables defined using
> > fortran 90 modules.
> >  My question is: Can I use 'include PETSc include file' and 'use
> > MyModule' in the program at the same time?
> yes.
> > If so, in what sequence should I put 'include XXX', 'use XXX' and
> > 'implicit' statements?
> The following should work.
> use foo
> implicit none
> > Another general question is whether I can use fortran 90 features
> > such as 'module' and dynamic allocation on a parallel system of
> > MPI-1 standard? Any reference on such programming work will be also
> > appreciated.
> I don't see why not. f90 issues you mentioned are unrelated to MPI
> Satish
> > _________________________________________________________________
> > 约会说不清地方?来试试微软地图最新msn互动功能!
> > http://ditu.live.com/?form=TL&swm=1
Messenger10年嘉年华,礼品大奖等你拿!
http://10.msn.com.cn
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090624/4150f30d/attachment.htm>
