Matrix Dense for CG
Tue Jun 16 19:11:14 CDT 2009
   Are you asking for sample dense matrices that CG has difficulty
with or are you asking for an example code that shows how to use CG on
a dense matrix in PETSc. If the later, it is the same as the other
examples, KSPCreate(), KSPSetType(ksp,KSPCG). KSPSetOperators() the
only difference is using MatCreateSeqDense() or MatCreateMPIDense().
    Barry
On Jun 13, 2009, at 12:31 PM, Santolo Felaco wrote:
> Hi,
> someone has some examples where the CG is used with a dense matrix?
> I need a system difficult to solve with the CG
> Thank you.
> S.F.
