Can PETSc detect the number of CPUs on each computer node?
Tue Jun 16 13:29:14 CDT 2009
On Tue, Jun 16, 2009 at 1:13 PM, Alex Peyser <peyser.alex at gmail.com> wrote:
> On Tuesday 16 June 2009 01:53:35 pm Matthew Knepley wrote:
> > On Tue, Jun 16, 2009 at 12:38 PM, xiaoyin ji
> > <sapphire.jxy at gmail.com<mailto:sapphire.jxy at gmail.com>> wrote: Hi there,
> > I'm using PETSc MATMPIAIJ and ksp solver. It seems that PETSc will run
> > obviously faster if I set the number of CPUs close to the number of
> > computer nodes in the job file. By default MPIAIJ matrix is stored in
> > different processors and ksp solver will communicate for each step,
> > however since on each node several CPUs share the same memory while
> > ksp may still try to communicate through network card, this may mess
> > up a bit. Is there any way to detect which CPUs are sharing the same
> > memory? Thanks a lot.
> > The interface for this is mpirun or the job submission mechanism.
> >    Matt
> > Best,
> > Xiaoyin Ji
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> their
> > experiments lead. -- Norbert Wiener
> I had a question on what is the best approach for this. Most of the time is
> spent inside of BLAS, correct? So wouldn't you maximize your operations by
> running one MPI/PETSC job per board (per shared memory), and use a
> multi-threaded BLAS that matches your board? You should cut down
> communications by some factor proportional to the number of threads per
> board, and the BLAS itself should better optimize most of your operations
> across the board, rather than relying on higher order parallelisms.
This is a common misconception. In fact, most time is spent in MatVec or
BLAS1, neither of which benefit from MT BLAS.
  Matt
> Regards,
> Alex Peyser
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090616/c1c27497/attachment.htm>
