VecView behaviour
Andreas Grassl Andreas.Grassl at student.uibk.ac.at
Thu Jun 4 17:13:50 CDT 2009
Barry Smith schrieb:
>    Run with GMRES, what happens?
Same behaviour...
>>>>> When properly running nn-cg (are you sure everything is symmetric?)
>>>>> should require 10-30 iterations (certainly for model problems)
>>>> ok, this was the number I expected.
>>>>>> nn-cg on 2 nodes 229 iterations, condition 6285
>>>>>> nn-cg on 4 nodes 331 iterations, condition 13312
>>>>> Are you sure that your operator has the null space of only constants?
>>>> no, I didn't touch anything regarding the null space since I thought
>>>> it would be
>>>> done inside the NN-preconditioner. Does this mean I have to set up a
>>>> null space
>>>> of the size of the Schur complement system, i.e. the number of
>>>> interface DOF's?
>>>  No, I don't think you need to do anything about the null space. The
>>> code in PETSc for NN is for (and only for) a null space of constants.
>>> BTW: with 2 or 4 subdomains they all touch the boundary and likely don't
>>> have a null space anyways.
>>> Run with -ksp_view and make sure the local solves are being done with LU
>> I don't find the anomalies... setting local_ksp-rtol to 1e-8 doesn't
>> change anything
>> the options passed are:
>> -is_localD_ksp_type preonly
>> -is_localD_pc_factor_shift_positive_definite
>> -is_localD_pc_type lu
>> -is_localN_ksp_type preonly
>> -is_localN_pc_factor_shift_positive_definite
>> -is_localN_pc_type lu
>> -ksp_rtol 1e-8
>> -ksp_view
>> #-is_localD_ksp_view
>> #-is_localN_ksp_view
>> #-nn_coarse_ksp_view
>> # -pc_is_remove_nullspace_fixed this option doesn't produce any effect
>> -log_summary
>> -options_left
>> and produce:
>> -ksp_view:
>> KSP Object:
>>  type: cg
>>  maximum iterations=10000
>>  tolerances:  relative=1e-08, absolute=1e-50, divergence=10000
>>  left preconditioning
>> PC Object:
>>  type: nn
>>  linear system matrix = precond matrix:
>>  Matrix Object:
>>    type=is, rows=28632, cols=28632
>>      Matrix Object:(is)
>>        type=seqaij, rows=7537, cols=7537
>>        total: nonzeros=359491, allocated nonzeros=602960
>>          using I-node routines: found 4578 nodes, limit used is 5
>>      Matrix Object:(is)
>>        type=seqaij, rows=7515, cols=7515
>>        total: nonzeros=349347, allocated nonzeros=601200
>>          using I-node routines: found 5159 nodes, limit used is 5
>>      Matrix Object:(is)
>>        type=seqaij, rows=7533, cols=7533
>>        total: nonzeros=357291, allocated nonzeros=602640
>>          using I-node routines: found 4739 nodes, limit used is 5
>>      Matrix Object:(is)
>>        type=seqaij, rows=7360, cols=7360
>>        total: nonzeros=364390, allocated nonzeros=588800
>>          using I-node routines: found 3602 nodes, limit used is 5
>> -is_local...:
>> KSP Object:(is_localD_)
>>  type: preonly
>>  maximum iterations=10000, initial guess is zero
>>  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>> PC Object:(is_localD_)
>>  type: lu
>>    LU: out-of-place factorization
>>      matrix ordering: nd
>>    LU: tolerance for zero pivot 1e-12
>>    LU: using Manteuffel shift
>>    LU: factor fill ratio needed 4.73566
>>         Factored matrix follows
>>        Matrix Object:
>>          type=seqaij, rows=6714, cols=6714
>>          package used to perform factorization: petsc
>>          total: nonzeros=1479078, allocated nonzeros=1479078
>>            using I-node routines: found 2790 nodes, limit used is 5
>>  Matrix Object:
>>    total: nonzeros=312328, allocated nonzeros=312328
>>      using I-node routines: found 4664 nodes, limit used is 5
>> KSP Object:(is_localN_)
>>  type: preonly
>> PC Object:(is_localN_)
>>  type: lu
>>      matrix ordering: nd
>>    LU: factor fill ratio needed 5.07571
>>        Matrix Object:
>>          total: nonzeros=1824671, allocated nonzeros=1824671
>>            using I-node routines: found 2939 nodes, limit used is 5
>>  Matrix Object:(is)
>> -nn_coarse_ksp_view:
>> KSP Object:(nn_coarse_)
>>  type: preonly
>> PC Object:(nn_coarse_)
>>  type: redundant
>>    Redundant preconditioner: First (color=0) of 4 PCs follows
>>  KSP Object:(redundant_)
>>    type: preonly
>>  PC Object:(redundant_)
>>    type: lu
>>        matrix ordering: nd
>>      LU: factor fill ratio needed 1
>>          Matrix Object:
>>            type=seqaij, rows=4, cols=4
>>            total: nonzeros=4, allocated nonzeros=4
>>              not using I-node routines
>>    Matrix Object:
>>  Matrix Object:
>>    type=mpiaij, rows=4, cols=4
>>    total: nonzeros=4, allocated nonzeros=68
>>      not using I-node (on process 0) routines
>> cheers,
>> ando
>> /"\                               Grassl Andreas
>> \ /    ASCII Ribbon Campaign      Uni Innsbruck Institut f. Mathematik
>>  X      against HTML email        Technikerstr. 13 Zi 709
>> / \                               +43 (0)512 507 6091
 \ /      ASCII Ribbon
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090605/1ed39492/attachment.pgp>
