VecView behaviour
Wed Jun 3 10:51:04 CDT 2009
   When properly running nn-cg (are you sure everything is symmetric?)
should require 10-30 iterations (certainly for model problems)
> nn-cg on 2 nodes 229 iterations, condition 6285
> nn-cg on 4 nodes 331 iterations, condition 13312
   Are you sure that your operator has the null space of only constants?
     Barry
On Jun 3, 2009, at 5:29 AM, Andreas Grassl wrote:
> Barry Smith schrieb:
>>   Hmm, it sounds like the difference between local "ghosted" vectors
>> and the global parallel vectors. But I do not understand why any of
>> the
>> local vector entries would be zero.
>> Doesn't the vector X that is passed into KSP (or SNES) have the
>> global
>> entries and uniquely define the solution? Why is viewing that not
>> right?
> I still don't understand fully the underlying processes of the whole
> PCNN
> solution procedure, but trying around I substituted
> MatCreateIS(commw, ind_length, ind_length, PETSC_DECIDE, PETSC_DECIDE,
> gridmapping, &A);
> by
> MatCreateIS(commw, PETSC_DECIDE, PETSC_DECIDE, actdof, actdof,
> gridmapping, &A);
> and received the needed results.
> Furthermore it seems, that the load balance is now better, although
> I still
> don't reach the expected values, e.g.
> ilu-cg 320 iterations, condition 4601
> cg only 1662 iterations, condition 84919
> or is it not to expect, that nn-cg is faster than ilu-cg?
> cheers,
> ando
> /"\                               Grassl Andreas
> \ /    ASCII Ribbon Campaign      Uni Innsbruck Institut f. Mathematik
>  X      against HTML email        Technikerstr. 13 Zi 709
> / \                               +43 (0)512 507 6091
