VecView behaviour
Jed Brown jed at 59A2.org
Wed Jun 3 09:41:00 CDT 2009
Andreas Grassl wrote:
> Barry Smith schrieb:
>>    Hmm, it sounds like the difference between local "ghosted" vectors
>> and the global parallel vectors. But I do not understand why any of the
>> local vector entries would be zero.
>> Doesn't the vector X that is passed into KSP (or SNES) have the global
>> entries and uniquely define the solution? Why is viewing that not right?
> I still don't understand fully the underlying processes of the whole PCNN
> solution procedure, but trying around I substituted
> MatCreateIS(commw, ind_length, ind_length, PETSC_DECIDE, PETSC_DECIDE,
> gridmapping, &A);
This creates a matrix that is bigger than you want, and gives you the
dead values at the end (global dofs that are not in the range of the
LocalToGlobalMapping.
This from the note on MatCreateIS:
| m and n are NOT related to the size of the map, they are the size of the part of the vector owned
| by that process. m + nghosts (or n + nghosts) is the length of map since map maps all local points
| plus the ghost points to global indices.
> by
> MatCreateIS(commw, PETSC_DECIDE, PETSC_DECIDE, actdof, actdof, gridmapping, &A);
This creates a matrix of the correct size, but it looks like it could
easily end up with the "wrong" dofs owned locally.  What you probably
want to do is:
1. Resolve ownership just like with any other DD method.  This
partitions your dofs into n owned dofs and ngh ghosted dofs on each
process.  The global sum of n is N, the size of the global vectors that
the solver will interact with.
2. Make an ISLocalToGlobalMapping where all the owned dofs come first,
mapping (0..n-1) to (rstart..rstart+n-1), followed by the ghosted dofs
(local index n..ngh-1) which map to remote processes.  (rstart is the
global index of the first owned dof)
One way to do this is to use MPI_Scan to find rstart, then number all
the owned dofs and scatter the result.  The details will be dependent on
how you store your mesh.  (I'm assuming it's unstructured, this step is
trivial if you use a DA.)
3. Call MatCreateIS(comm,n,n,PETSC_DECIDE,PETSC_DECIDE,mapping,&A);
> Furthermore it seems, that the load balance is now better, although I still
> don't reach the expected values, e.g.
> ilu-cg 320 iterations, condition 4601
> cg only 1662 iterations, condition 84919
> nn-cg on 2 nodes 229 iterations, condition 6285
> nn-cg on 4 nodes 331 iterations, condition 13312
> or is it not to expect, that nn-cg is faster than ilu-cg?
It depends a lot on the problem.  As you probably know, for a second
order elliptic problem with exact subdomain solves, the NN
preconditioned operator (without a coarse component) has condition
number that scales as
  (1/H^2)(1 + log(H/h))^2
where H is the subdomain diameter and h is the element size.
In contrast, overlapping additive Schwarz is
  1/H^2
and block Jacobi is
  1/(Hh)
(the original problem was 1/h^2)
In particular, there is no reason to expect that NN is uniformly better
than ASM, although it may be for certain problems.  When a coarse
solve is used, NN becomes
  (1 + log(H/h))^2
which is quasi-optimal (these methods are known as BDDC, which is
essentially equivalent to FETI-DP).  The key advantage over multigrid
(or multilivel Schwarz) is improved robustness with variable
coefficients.  My understanding is that PCNN is BDDC, and uses direct
subdomain solves by default, but I could have missed something.  In
particular, if the coarse solve is missing or inexact solves are used,
you could easily see relatively poor scaling.  AFAIK, it's not for
vector problems at this time.
Good luck.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090603/e2be694d/attachment.pgp>
