PETSC debugger
Sat Jul 18 23:30:59 CDT 2009
   Try using -display vyan2000-linux:0.0
   Shouldn't make any difference but since it appears you are running
everything on the same machine what you have given should work.
    Barry
On Jul 18, 2009, at 11:24 PM, Ryan Yan wrote:
> Hi All,
> I am tring to use the PETSc runtime option -start_in_debugger.
> However, when I attach the debugger at run time to each process,
> there are error messages and I only get one gdb window(Am I suppose
> to get as many as the number of the processes?)
> vyan2000 at vyan2000-linux:~/local/PPETSc/petsc-2.3.3-p15/src/ksp/ksp/
> examples/tutorials/ttt2$ mpirun -np 2 ./rpisolve -
> ksp_monitor_true_residual -start_in_debugger -display :0.0
> [1]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26307 on
> display :0.0 on machine vyan2000-linux
> [0]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26306 on
> Then, only a *single* gdb window prompts out. When I run with 3
> process, there are only *two* gdb windows.
> Thank you very much in advance,
> Yan
