further about MatGetSubMatrix_MPIDense(), and MatTranspose() and MatGetSubMatrix()
Yujie recrusader at gmail.com
Sat Jan 31 18:33:00 CST 2009
Hi, PETSc Developers
I have sent the matrices and codes to you. However, the sizes of the
matrices are a little big and reach your limit. If you need it. I will
further send them to you. thanks a lot.
Yujie
---------- Forwarded message ----------
Date: Sat, Jan 31, 2009 at 4:25 PM
Subject: further about MatGetSubMatrix_MPIDense(), and MatTranspose() and
MatGetSubMatrix()
To: PETSc users list <petsc-users at mcs.anl.gov>
Hi, PETSc Developers:
Recently, I try to find the bug in MatGetSubMatrix_MPIDense(). The problem
should be in "av = v + ((Mat_SeqDense *)newmatd->A->data)->lda*icol[i];" of
the following codes.
Since "av" and "v" are used for parent matrix, I think it should not be
"newmatd" but "mat" in the codes. I have revised it. The results are
correct.
224: for (i=0; i<ncols; i++) {
225: av = v + ((Mat_SeqDense *)newmatd->A->data)->lda*icol[i];
226: for (j=0; j<nrows; j++) {
227: *bv++ = av[irow[j] - rstart];
228: }
229: }
Further problem is to use MatTranspose() and MatGetSubMatrix() when
MPIAIJ*MPIDense. The attached files are the testing codes (I revised
ex113.c). I have used Valgrind to test it. The errors are as follows. I
obtain them from Valgrind output. The command is "valgrind -v
--trace-children=yes --show-reachable=yes --track-fds=yes --leak-check=full
mpirun -np 2 ex113".
This "Invalid read of size 4" will lead to the uncertain output. I can't
figure out where the problem is. Could you give me some help? The used
system is "Red Hat Enterprise Linux ES release 3". thanks.
"Finishing MatMatMult
Finishing MatTranspose
==23027==
==23027== Invalid read of size 4
==23027== at 0x4253F2C: MatGetSubMatrix_MPIDense(_p_Mat*, _p_IS*, _p_IS*,
int, MatReuse, _p_Mat**) (mpidense.c:227)
==23027== by 0x41D4F56: MatGetSubMatrix(_p_Mat*, _p_IS*, _p_IS*, int,
MatReuse, _p_Mat**) (matrix.c:6162)
==23027== by 0x8049643: main (ex113.c:75)
==23027== Address 0x553de30 is 8 bytes after a block of size 46,952 alloc'd
==23027== at 0x401AC01: malloc (vg_replace_malloc.c:207)
==23027== by 0x46992C1: PetscMallocAlign(unsigned int, int, char const*,
char const*, char const*, void**) (mal.c:40)
==23027== by 0x46A45C3: PetscTrMallocDefault(unsigned int, int, char const*,
char const*, char const*, void**) (mtr.c:194)
==23027== by 0x413E56F: MatSeqDenseSetPreallocation_SeqDense (dense.c:1945)
==23027== by 0x413E26D: MatSeqDenseSetPreallocation(_p_Mat*, double*)
(dense.c:1926)
==23027== by 0x425C193: MatMPIDenseSetPreallocation_MPIDense
(mpidense.c:1549)
==23027== by 0x425CE71: MatMPIDenseSetPreallocation(_p_Mat*, double*)
(mpidense.c:1699)
==23027== by 0x425B4E5: MatTranspose_MPIDense(_p_Mat*, MatReuse, _p_Mat**)
(mpidense.c:963)
==23027== by 0x41C3435: MatTranspose(_p_Mat*, MatReuse, _p_Mat**)
(matrix.c:3843)
==23027== by 0x8049482: main (ex113.c:62)
==23027==
==23027== at 0x4253F2E: MatGetSubMatrix_MPIDense(_p_Mat*, _p_IS*, _p_IS*,
==23027== Address 0x553de34 is 12 bytes after a block of size 46,952 alloc'd
(dense.c:1926)
(mpidense.c:1549)
(mpidense.c:1699)
(mpidense.c:963)
(matrix.c:3843)
Finishing MatGetSubMatrix
Yujie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090131/84a6bfb0/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090131/84a6bfb0/attachment.obj>
