Problem in convergence after upgrade to petsc 3.0.0
Fri Jan 30 23:20:52 CST 2009
    The convergence of both of those is GARBAGE. The true residual
gets hugely worse in the first
step and then stays bad in both cases. The fact that the
preconditioned residual norm gets small
better with the old PETSc then the new is kind of irrelevent. The
solution that KSP claims to give in
both cases is frankly crap.
   Send me the output for both with -ksp_monitor_true_residual with -
ksp_type gmres with old and
new PETSc.
    Barry
On Jan 30, 2009, at 11:11 PM, Randall Mackie wrote:
> 	Barry,
> 	I've run ex10 from 2.3.3-p11 and from 3.0.0-p2 on the same
> binaryoutput
> using the same parameters input to ex10 (ksp=bcgsl and pc=bjacobi,
> sub_pc=ilu)
> and the convergence is different. Note, this is the binaryoutput
> from the
> v 2.3.3-p11.
> Here is the convergence for ex10 from 2.3.3-p11:
> [rmackie ~/SPARSE/PETsc/petsc-2.3.3-p11/src/ksp/ksp/examples/
> tutorials] ./cmd_test
>  0 KSP preconditioned resid norm 2.434324107505e-05 true resid norm
> 3.334159901684e-02 ||Ae||/||Ax|| 1.000000000000e+00
>  2 KSP preconditioned resid norm 4.170258940641e-07 true resid norm
> 1.624814448703e+04 ||Ae||/||Ax|| 4.873234927583e+05
>  4 KSP preconditioned resid norm 8.984963207977e-08 true resid norm
> 2.848180153976e+04 ||Ae||/||Ax|| 8.542422193181e+05
>  6 KSP preconditioned resid norm 3.526062648105e-08 true resid norm
> 1.884591980560e+04 ||Ae||/||Ax|| 5.652374319564e+05
>  8 KSP preconditioned resid norm 1.241153849592e-08 true resid norm
> 1.045401827970e+04 ||Ae||/||Ax|| 3.135427990247e+05
> 10 KSP preconditioned resid norm 5.141701606491e-09 true resid norm
> 5.371087738119e+03 ||Ae||/||Ax|| 1.610926859088e+05
> 12 KSP preconditioned resid norm 2.591522726108e-09 true resid norm
> 3.519633363751e+03 ||Ae||/||Ax|| 1.055628244456e+05
> 14 KSP preconditioned resid norm 1.452300847705e-09 true resid norm
> 2.509415501645e+03 ||Ae||/||Ax|| 7.526380184636e+04
> 16 KSP preconditioned resid norm 8.978785776773e-10 true resid norm
> 1.872610647707e+03 ||Ae||/||Ax|| 5.616439231845e+04
> 18 KSP preconditioned resid norm 5.743601707920e-10 true resid norm
> 1.266421550645e+03 ||Ae||/||Ax|| 3.798322779917e+04
> 20 KSP preconditioned resid norm 3.678705188041e-10 true resid norm
> 7.536064149571e+02 ||Ae||/||Ax|| 2.260258767363e+04
> 22 KSP preconditioned resid norm 2.687340247327e-10 true resid norm
> 5.533061905955e+02 ||Ae||/||Ax|| 1.659507062981e+04
> 24 KSP preconditioned resid norm 2.142070779181e-10 true resid norm
> 4.684485692902e+02 ||Ae||/||Ax|| 1.404997309978e+04
> 26 KSP preconditioned resid norm 1.927583902818e-10 true resid norm
> 6.146993326148e+02 ||Ae||/||Ax|| 1.843640829296e+04
> 28 KSP preconditioned resid norm 1.330050553611e-10 true resid norm
> 4.217422387701e+02 ||Ae||/||Ax|| 1.264913055181e+04
> 30 KSP preconditioned resid norm 1.125778226987e-10 true resid norm
> 3.058702983977e+02 ||Ae||/||Ax|| 9.173834111652e+03
> 32 KSP preconditioned resid norm 8.786382414490e-11 true resid norm
> 2.001904013306e+02 ||Ae||/||Ax|| 6.004223169665e+03
> 34 KSP preconditioned resid norm 6.396029789854e-11 true resid norm
> 1.761414838880e+02 ||Ae||/||Ax|| 5.282934504701e+03
> 36 KSP preconditioned resid norm 5.462116905743e-11 true resid norm
> 1.540860953921e+02 ||Ae||/||Ax|| 4.621436881724e+03
> 38 KSP preconditioned resid norm 5.410616131680e-11 true resid norm
> 1.910613970561e+02 ||Ae||/||Ax|| 5.730420936308e+03
> 40 KSP preconditioned resid norm 7.946054076400e-11 true resid norm
> 2.743761797072e+02 ||Ae||/||Ax|| 8.229244781230e+03
> 42 KSP preconditioned resid norm 3.519925335531e-11 true resid norm
> 1.022381658728e+02 ||Ae||/||Ax|| 3.066384603244e+03
> Number of iterations =  42
> Here is the convergence for ex10 from 3.0.0-p2:
> rmackie ~/SPARSE/PETsc/petsc-3.0.0-p2/src/ksp/ksp/examples/
>  2 KSP preconditioned resid norm 4.798562862178e-07 true resid norm
> 1.642225014976e+04 ||Ae||/||Ax|| 4.925453677690e+05
>  4 KSP preconditioned resid norm 1.587355624039e-07 true resid norm
> 3.502938376404e+04 ||Ae||/||Ax|| 1.050620989904e+06
>  6 KSP preconditioned resid norm 8.015528577103e-08 true resid norm
> 2.536595627800e+04 ||Ae||/||Ax|| 7.607900348506e+05
>  8 KSP preconditioned resid norm 3.039306325625e-08 true resid norm
> 1.253662335500e+04 ||Ae||/||Ax|| 3.760054623856e+05
> 10 KSP preconditioned resid norm 1.729327127129e-08 true resid norm
> 8.080934369743e+03 ||Ae||/||Ax|| 2.423679309940e+05
> 12 KSP preconditioned resid norm 1.039787850500e-08 true resid norm
> 4.777791224801e+03 ||Ae||/||Ax|| 1.432982030162e+05
> 14 KSP preconditioned resid norm 5.025780191774e-09 true resid norm
> 3.147651686153e+03 ||Ae||/||Ax|| 9.440614064618e+04
> 16 KSP preconditioned resid norm 3.311781967950e-09 true resid norm
> 2.688053658600e+03 ||Ae||/||Ax|| 8.062161797467e+04
> 18 KSP preconditioned resid norm 5.621276662229e-09 true resid norm
> 3.098810918425e+03 ||Ae||/||Ax|| 9.294128085637e+04
> 20 KSP preconditioned resid norm 1.184533040734e-08 true resid norm
> 5.469874887175e+03 ||Ae||/||Ax|| 1.640555656737e+05
> 22 KSP preconditioned resid norm 2.494642590524e-08 true resid norm
> 1.003335643955e+04 ||Ae||/||Ax|| 3.009260723962e+05
> 24 KSP preconditioned resid norm 5.136091311727e-08 true resid norm
> 1.828432513826e+04 ||Ae||/||Ax|| 5.483937686680e+05
> 26 KSP preconditioned resid norm 9.627430082715e-08 true resid norm
> 1.175348501769e+04 ||Ae||/||Ax|| 3.525171366783e+05
> 28 KSP preconditioned resid norm 6.409712928943e-08 true resid norm
> 5.524687582334e+03 ||Ae||/||Ax|| 1.656995388716e+05
> 30 KSP preconditioned resid norm 6.013091685526e-07 true resid norm
> 1.371019320496e+04 ||Ae||/||Ax|| 4.112038297274e+05
> 32 KSP preconditioned resid norm 7.026562454712e-07 true resid norm
> 1.053982255306e+04 ||Ae||/||Ax|| 3.161162890759e+05
> 34 KSP preconditioned resid norm 4.086784421188e-07 true resid norm
> 5.503180350963e+03 ||Ae||/||Ax|| 1.650544818856e+05
> 36 KSP preconditioned resid norm 1.651444280250e-06 true resid norm
> 1.984011183420e+04 ||Ae||/||Ax|| 5.950557987388e+05
> 38 KSP preconditioned resid norm 1.058319572456e-06 true resid norm
> 1.403784173466e+04 ||Ae||/||Ax|| 4.210308488073e+05
> 40 KSP preconditioned resid norm 4.341084013969e-05 true resid norm
> 3.837773616917e+05 ||Ae||/||Ax|| 1.151046659453e+07
> 42 KSP preconditioned resid norm 4.190225826231e-07 true resid norm
> 6.768382935039e+03 ||Ae||/||Ax|| 2.030011497535e+05
> 44 KSP preconditioned resid norm 1.054511038261e-06 true resid norm
> 4.966771429542e+03 ||Ae||/||Ax|| 1.489662036615e+05
> 46 KSP preconditioned resid norm 5.351004248086e-07 true resid norm
> 5.112611747101e+03 ||Ae||/||Ax|| 1.533403285343e+05
> 48 KSP preconditioned resid norm 7.104477128923e-07 true resid norm
> 5.478002736962e+03 ||Ae||/||Ax|| 1.642993407183e+05
> 50 KSP preconditioned resid norm 1.162050733932e-06 true resid norm
> 5.395393687747e+03 ||Ae||/||Ax|| 1.618216836278e+05
> When I output binaryoutput using my code compiled under 3.0.0-p2 and
> run ex10, I get exactly
> the same output as above. In other words, the matrix/rhs are exactly
> the same (as they
> should be since I didn't change anything), and something about 3.0.0-
> p2 using BCGSL and ILU
> is not working correctly.
> I changed ksptype to gmres, and I get the same convergence for both
> 2.3.3-p11 and for
> 3.0.0-p2. Therefore, I conclude that bcgsl (PCBCGSL) is not working
> correctly under 3.0.0-p2.
> Randy
> Barry Smith wrote:
>>  Run the old code with -ksp_view_binary this will create a file
>> called binaryoutput; you can then
>> run src/ksp/ksp/examples/tutorials/ex10.c using that input file.
>> Use the ex10 from the old version
>> of PETSc and then the ex10 from the new version. Do they have they
>> same convergence?
>> Now run the new code (that is build your code with petsc-3.0.) with
>> -ksp_view_binary and run that
>> binaryoutput file with the old and new ex10 to see what happens.
>>   Basically there are two possible changes with the change in the
>> version:
>> 1) the matrix/right hand side has changed or
>> 2) the solver has changed to behave differently.
>>   By running the four cases you can start to get a handle on what
>> has actually changed, this will
>> lead you to what needs to be investigated next.
>>   Barry
>> On Jan 30, 2009, at 8:01 PM, Randall Mackie wrote:
>>> I just downloaded and compiled Petsc 3.0.0-p2, and after making
>>> some changes
>>> in my code to specify the correct location of the include files,
>>> finally
>>> got everything to compile okay.
>>> Now, I'm trying to run my test problem, and it's not converging.
>>> When I say
>>> not converging, the first line (with ksp_monitor_true_residual)
>>> shows that
>>> the true and preconditioned residuals are the same as before, but
>>> immediately
>>> thereafter, the preconditioned residual fails to go below 1e-8
>>> whereas before
>>> it quickly went down to 1e-15.
>>> The options in my command file are:
>>> -ksp_type bcgsl
>>> -pc_type bjacobi
>>> -sub_pc_type ilu
>>> -sub_pc_factor_levels 3
>>> -sub_pc_factor_fill 6
>>> The only thing I see in the Change notes are that the ILU defaults
>>> to shifting
>>> so that it's p.d. but I don't see an easy way to turn this off by
>>> the command
>>> line to see if that's the problem. I tried to do it in my program,
>>> but it's unclear
>>> if I did that correctly.
>>> Any suggestions?
>>> Thanks, Randy
