shared libraries for PETSc 3.0.0-p2 + Hypre
Shao-Ching Huang schuang at ats.ucla.edu
Fri Jan 30 14:59:42 CST 2009
Satish Balay wrote:
> Note - in our default approach, hypre symbols are pulled into petsc
> sharedlibraries [and not user binaries - so the user binaries will
> remain small]
This is cool! Thanks.
Shao-Ching
> Satish
> On Fri, 30 Jan 2009, Shao-Ching Huang wrote:
>> Satish:
>> Thanks for the suggestion. I will just follow the standard approach
>> then -- PETSc shared libraries with external .a libraries.
>> Shao-Ching
>> Satish Balay wrote:
>>> We build external packages minimally only. So the PETSc shared
>>> libraries will link with most of the external .a libraries. This works
>>> fine for us.
>>> To build shared hypre library - you can try the following and see if
>>> it works:
>>> cd $PETSC_DIR
>>> make SHLIBS=libHYPRE shared
>>> Satish
>>>> Hi,
>>>> I am trying to build shared library version of PETSC 3.0.0-p2 with
>>>> Hypre (Fedora 10 Linux on x86_64).
>>>> With "configure --with-shared=1 ...", it does build shared libraries
>>>> for PETSC, but the Hypre part is still static. The file
>>>> externalpackages/hypre-2.4.0b/src/config.log shows that
>>>> "--enable-shared" (for configuring Hypre) is not there.
>>>> Is there a way to build shared libraries for Hypre from PETSc's
>>>> configure command line?
>>>> Thanks.
>>>> Shao-Ching
>>>> My complete PETSc configure command:
>>>> ./config/configure.py  --with-debugging=1 --with-shared=1 \
>>>> --with-cc=mpicc --with-fc=mpif90 --with-cxx=mpicxx        \
>>>> --with-blas-lapack-dir=/usr/lib64                         \
>>>> --download-hypre=yes
>>>> The first few lines of externalpackages/hypre-2.4.0b/src/config.log
>>>> (reformatted):
>>>> $ ./configure
>>>> --prefix=/home/schuang/local/petsc-3.0.0-p2-shared/linux-gnu-c-debug
>>>> CC=mpicc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -g3
>>>> CXX=mpicxx -Wall -Wwrite-strings -Wno-strict-aliasing -g -fPIC
>>>> F77=mpif90 -fPIC -Wall -Wno-unused-variable -g
>>>> --with-MPI-include=/usr/include/openmpi/1.2.4-gcc/64
>>>> --with-MPI-lib-dirs= --with-MPI-libs=nsl rt --with-blas-libs=
>>>> --with-blas-lib-dir= --with-lapack-libs= --with-lapack-lib-dir=
>>>> --with-blas=yes --with-lapack=yes --without-babel --without-mli
>>>> --without-fei --without-superlu
