Time to execute KSPSetUp
jerome ho jerome.snho at gmail.com
Thu Jan 29 19:46:12 CST 2009
Hi
I wonder if there's any way I can speed up KSPSetUp()?
On larger test cases with 1e8 unknowns, it's taking more than 17 hours (and
still incomplete) to execute this command across 3 processors with
BoomerAMG,
where as the whole setup+solving takes 2 min if the problem size is 1e6.
I've verified that the matrices has completed assembly and I'm using the
non-debugging Petsc version.
Jerome
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090130/069eab5a/attachment.htm>
