Thanks for the quick and helpful suggestions. I have used MatSetOptions() using MAT_IGNORE_ZERO_ENTRIES with -pc_type sor. This gives me the same Stiffness matrix in both cases (with and without excluding zero entries). Further the results are the same, including the number of iterations.
However, the number of iterations to convergence is 70. Earlier I used to use PCASM with KSPCG. This required 17 iterations. Barry mentioned "spooles" with pc_type cholesky. But I am skeptical about its performs on systems with over a million degrees of freedom. My matrices are positive definite, thus CG may be ideally suited. But I am not sure what kind of preconditioner would best suit in parallel.
Any suggestions on preconditioner-solver combinations for very large (1-10 million dof) positive definite systems?
Thanks again
Best Regards
Irfan
----- Original Message -----
To: "PETSc users list" <petsc-users at mcs.anl.gov>
Sent: Sunday, January 25, 2009 9:42:42 PM GMT -05:00 US/Canada Eastern
Subject: Re: parallel solvers and matrix structure
On Jan 25, 2009, at 8:19 PM, Khan, Irfan wrote:
> Dear Petsc team
> Firstly, thanks for developing PETSc. I have been using it to
> parallelize a linear finite element code to use with a parallel
> lattice Boltzmann code. It has helped me a lot untill now.
> I have some questions about the way the parallel solvers handles
> matrices with varying zeros in the matrix.
> I have found that the more MatSetValue() commands I use in my code
> the slower it gets. Therefore I initialize the parallel Stiffness
> matrix to 0.0.
I don't know what you mean by this. You should NOT call
MatZeroEntries() on the matrix initially. This will destroy your
preallocation information.
Call MatZeroEntries() after you have filled it up and used it, when
you are ready to start again.
> I then fill in the values using an "if" conditions to eliminate zero
> entries into the parallel Stiffness matrix. This reduces the number
> of times MatSetValue() is called greatly (5-15 times). I also
> approximate the number of non-zero entries into the parallel matrix,
> that I create using MatCreateMPIAIJ. I have attached outputs of
> running my code with "-info"; one with the "if" condition and the
> other without the conditions (at the end of the email).
If you are using the SeqAIJ or MPIAIJ matrices then you can simply
call MatSetOption(mat,MAT_IGNORE_ZERO_ENTRIES)
and it will not put in those locations with zero value.
> I have also compared the matrices generated by using the "if"
> condition and the one generated without the "if" condition. They are
> the same except for the extra zero entries in the later case. But
> what I realize is that during solving, the matrix generated with the
> "if" condition is not converging while the matrix generated without
> the "if" conditions converges in 17 iterations. I use KSPCG.
First run both cases with -pc_type lu and confirm that they both
produce the same solution to the linear system (on one process).
Also confirm that the matrix is symmetric positive definite so you
can use CG.
The reason for the difference in converging is because the default
solver that PETSc uses is ILU(0). The "quality" of an ILU
preconditioner depends on the
"nonzero" structure of the matrix, the more "nonzero" locations the
more likely there will be convergence and it will be faster. For ILU a
zero in a location is different
than not having that location at all. Likely you want to use a better
preconditioner; what about -pc_type sor? For moderate size problems,
say < 100,000 you may
want to use Cholesky direct solver. In parallel run config/
configure.py --download-spooles then run the code with -pc_type
cholesky -pc_factor_mat_solver_package spooles
Barry
> It would help me a lot if I can get some suggestions on how to use
> MatSetValue() optimally, the reason for KSPCG failing to converge
> and if something can be done. Also any suggestions on if I should
> not use an "if" condition to enter values into the Stiffness matrix
> to eliminate zero entries.
> I will be glad to send any other information if needed.
> Thanks in advance
> Best Regards
> Irfan
> WITHOUT "IF" CONDITION
> < [0] MatStashScatterBegin_Private(): Mesg_to: 1: size: 3464
> < [0] MatAssemblyBegin_MPIAIJ(): Stash has 432 entries, uses 0
> mallocs.
> < [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 66 X 66; storage space:
> 306 unneeded,4356 used
> < [0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during
> MatSetValues() is 216
> < [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 66
> < [0] Mat_CheckInode(): Found 14 nodes of 66. Limit used: 5. Using
> Inode routines
> < [1] MatAssemblyEnd_SeqAIJ(): Matrix size: 66 X 66; storage space:
> 465 unneeded,3576 used
> < [1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during
> MatSetValues() is 183
> < [1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 66
> < [1] Mat_CheckInode(): Found 23 nodes of 66. Limit used: 5. Using
> Inode routines
> 243 unneeded,972 used
> MatSetValues() is 72
> < [1] Mat_CheckCompressedRow(): Found the ratio (num_zerorows 12)/
> (num_localrows 66) < 0.6. Do not use CompressedRow routines.
> 504 unneeded,1116 used
> MatSetValues() is 99
> < [0] Mat_CheckCompressedRow(): Found the ratio (num_zerorows 0)/
> WITH "IF" CONDITION
>> [0] MatStashScatterBegin_Private(): Mesg_to: 1: size: 632
>> [0] MatAssemblyBegin_MPIAIJ(): Stash has 78 entries, uses 0 mallocs.
>> 118 unneeded,1304 used
>> MatSetValues() is 0
>> [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 26
>> [0] Mat_CheckInode(): Found 66 nodes out of 66 rows. Not using
>> Inode routines
>> 353 unneeded,1033 used
>> MatSetValues() is 6
>> [1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 26
>> [1] Mat_CheckInode(): Found 64 nodes out of 66 rows. Not using
>> Inode routines
>> [1] MatAssemblyEnd_SeqAIJ(): Matrix size: 66 X 24; storage space:
>> 14 unneeded,121 used
>> MatSetValues() is 0
>> [1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 12
>> [1] Mat_CheckCompressedRow(): Found the ratio (num_zerorows 48)/
>> (num_localrows 66) > 0.6. Use CompressedRow routines.
>> [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 66 X 18; storage space:
>> MatSetValues() is 0
>> [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 11
>> [0] Mat_CheckCompressedRow(): Found the ratio (num_zerorows 42)/
