Compiling and using PETSC with intel MKL
Sun Jan 25 14:26:00 CST 2009
On Jan 25, 2009, at 7:52 AM, Billy Araújo wrote:
> Hi,
> Before I compiled PETSC version 2.3.3-p6 with lapack/blas supplied
> with Intel MKL and everythin worked great:
> ./config/configure.py --with-cc=gcc --with-fc=g77 --download-lam=1 --
> with-blas-lapack-dir=/opt/intel/mkl/10.0.1.014 --with-debugging=no --
> with-shared=0
> Now I have tried PETSC version 3.0.0-p2 with OpenMPI and same Intel
> MKL version and it compiles but when I run my application I get the
> following error:
> MKL FATAL ERROR: libmkl_def.so: cannot open shared object file: No
> such file or directory
     It cannot find the location of the shared library at runtime.
You  may need to set a LD_LIBRARY_PATH or similar environmental variable
before running the program.
   Barry
> openmpi=1 --with-blas-lapack-dir=/opt/intel/mkl/10.0.1.014 --with-
> debugging=no --with-shared=0
> Regards,
> Billy.
