compiling petsc2-3.3-p15 against mvapich-0.9.9
Matt Funk mafunk at nmsu.edu
Thu Jan 22 16:46:52 CST 2009
Hi Satish,
looks like simply leaving out --with-cc=gcc and --with-fc=gfortran did the
trick.
thanks
matt
On Thursday 22 January 2009, Satish Balay wrote:
> Looks like this old version of mpi has MPI_Win_create() - but not the
> associated MPI_Win definition in its include.
> You can edit petscconf.h and remove the lines
> #ifndef PETSC_HAVE_MPI_WIN_CREATE
> #define PETSC_HAVE_MPI_WIN_CREATE 1
> #endif
> and then recompiling petsc.
> BTW: when you specify  --with-mpi-dir=/usr/mpi/mvapich-0.9.9/gcc
> PETSc configure will use mpicc/mpif77 etc as compilers.
> So its best not to specify '--with-cc=gcc --with-fc=gfortran' etcc
> Satish
> On Thu, 22 Jan 2009, Matt Funk wrote:
> > Hi Satish,
> > it still doesn't work, but something changed. I configure now with:
> > ./config/configure.py --with-mpi-dir=/usr/mpi/mvapich-0.9.9/gcc
> > --with-debugging=0 --with-log=0 --with-cc=gcc --with-fc=gfortran
> > --download-f-blas-lapack=1 --download-superlu=1 --download-superlu_dist=1
> > --download-spooles=1 --download-hypre=hypre-2.4.0b.tar.gz rather than
> > specifying the include dir and lib dir specifically.
> > Anyway, it passes through the configuration stage. After setting
> > PETSC_DIR and PETSC_ARCH, i do: make all test. This one fails.
> > The first couple error are printed to the screen as such:
> > In file included from vinv.c:6:
> > /home/mafunk/Packages/petsc-2.3.3-p15_Conf0/include/private/vecimpl.h:236
> >: error: expected specifier-qualifier-list before 'MPI_Win'
> > In file included from vscat.c:9:
> > In file included from vpscat.c:8:
> > In file included from vpscat.c:1370:
> > /home/mafunk/Packages/petsc-2.3.3-p15_Conf0/src/vec/vec/utils/vpscat.h:
> > In function 'VecScatterBegin_1':
> > /home/mafunk/Packages/petsc-2.3.3-p15_Conf0/src/vec/vec/utils/vpscat.h:65
> >: warning: implicit declaration of function 'MPI_Win_fence'
> >: error: 'VecScatter_MPI_General' has no member named 'window'
> > /home/mafunk/Packages/petsc-2.3.3-p15_Conf0/src/vec/vec/utils/vpscat.h:68
> >: warning: implicit declaration of function 'MPI_Put'
> > /home/mafunk/Packages/petsc-2.3.3-p15_Conf0/src/vec/vec/utils/vpscat.h:70
> > In file included from vpscat.c:1372:
> > In function 'VecScatterBegin_2':
> > I attached the config file.
> > thanks
> > matt
> > On Wednesday 21 January 2009, you wrote:
> > > Each time - do you see binary chars at the end of configure.log -
> > > after the _access test?
> > > I don't know why this would happen.
> > > Perhaps you can try with the same configure options - and send in the
> > > configure.log [petsc-maint at mcs.anl.gov] for us to comapre.
> > > Satish
> > > On Wed, 21 Jan 2009, Matt Funk wrote:
> > > > I tried it multiple from a fresh tarball each time. Same thing
> > > > everytime. Did you mean try with different configure options? If so,
> > > > which ones did you have in mind?
> > > > thanks
> > > > matt
> > > > On Wednesday 21 January 2009, Satish Balay wrote:
> > > > > Not sure what the issue is. I see the configure.log [from the
> > > > > rejected e-mail] - there are some binary chars at the end of the
> > > > > file.
> > > > > Perhaps you can retry and see? [after rm *.log]. If you still have
> > > > > issues - send configure.log to petsc-maint at mcs.anl.gov
> > > > > Satish
> > > > > > Hi,
> > > > > > i was wondering if there is any issues with compiling petsc based
> > > > > > on mvapich-0.9.9. I tells me that it is unable to configure with
> > > > > > given options. I configure as such:
> > > > > > --with-mpi-include=/usr/mpi/mvapich-0.9.9/gcc/include
> > > > > > --with-mpi-lib=/usr/mpi/mvapich-0.9.9/gcc/lib/libmpich.a
> > > > > > --download-superlu_dist=1 --download-spooles=1
> > > > > > I can compile  petsc against the mvapich2 libraries just fine.
> > > > > > thanks
> > > > > > matt
