Help with adding a new routine to the MATMFFD module
Rafael Santos Coelho rafaelsantoscoelho at gmail.com
Thu Jan 8 18:00:40 CST 2009
Hi Barry,
>   First run in the debugger and put a breakpoint in MatMFFDRegisterAll()
> make sure the code gets there.
> Then step through while it does the dynamic registration of the new method
> and make sure everything
> looks reasonable along the way.
Could you help me out with that? It's that I've never used PETSc in
debugging mode before.
Rafael
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090108/d3622cb3/attachment.htm>
