MatTranspose_MPIDense illegal read?
Tue Jan 6 21:29:01 CST 2009
    You need to reproduce the problem with petsc-3.0.0 the line number
251 below is meaningless
for 3.0.0 so doesn't help us at all.
Libraries linked from /home/yujie/codes/petsc-2.3.3-p8/lib/linux
    This could easily be a bug in PETSc here but we cannot find bugs
by just looking at the
code; we need at least to know exactly where it happens. And we're not
going to debug old
versions of PETSc.
   Please continue this thread only on petsc-maint at mcs.anl.gov
    Barry
On Jan 6, 2009, at 8:06 PM, Yujie wrote:
> Dear Barry:
> I will try to do it according to your advice. I tried to incearse
> and reduce the processor number, some cases are broken, others
> aren't. This invalid read problem always exists. If the erros exist,
> the following is the broken information,
> Invalid read can lead to the following errors? thanks.
> "[6]PETSC ERROR:
> p2_15964: p4_error: net_recv read: probable EOF on socket: 1
> rm_l_2_15965: (354.724282) net_send: could not write to fd=5, errno
> = 32"
> ==5821==
> ==5821== Invalid read of size 4
> ==5821== at 0x5143617: MatGetSubMatrix_MPIDense(_p_Mat*, _p_IS*,
> _p_IS*, int, MatReuse, _p_Mat**) (mpidense.c:251)
> ==5821== by 0x50C2D71: MatGetSubMatrix(_p_Mat*, _p_IS*, _p_IS*, int,
> MatReuse, _p_Mat**) (matrix.c:5744)
> ==5821== by 0x805BCE8: mySystem::MakeA(int) (mySystem.C:518)
> ==5821== by 0x80615A6: mySystem::Source(mySystem*, int) (mySystem.C:
> 1927)
> ==5821== by 0x806B5B1: main (myproject.C:293)
> ==5821== Address 0x8f06c64 is 12 bytes after a block of size 472,272
> alloc'd
> ==5821== at 0x401AC01: malloc (vg_replace_malloc.c:207)
> ==5821== by 0x558312D: PetscMallocAlign(unsigned int, int, char
> const*, char const*, char const*, void**) (mal.c:40)
> ==5821== by 0x558DA83: PetscTrMallocDefault(unsigned int, int, char
> const*, char const*, char const*, void**) (mtr.c:194)
> ==5821== by 0x50386A7: MatSeqDenseSetPreallocation_SeqDense (dense.c:
> 1875)
> ==5821== by 0x5038469: MatSeqDenseSetPreallocation(_p_Mat*, double*)
> (dense.c:1858)
> ==5821== by 0x514BC4B: MatMPIDenseSetPreallocation_MPIDense
> (mpidense.c:1175)
> ==5821== by 0x514C889: MatMPIDenseSetPreallocation(_p_Mat*, double*)
> (mpidense.c:1312)
> ==5821== by 0x514AD8B: MatTranspose_MPIDense(_p_Mat*, _p_Mat**)
> (mpidense.c:979)
> ==5821== by 0x50B2D85: MatTranspose(_p_Mat*, _p_Mat**) (matrix.c:3603)
> ==5821== by 0x805BCAA: mySystem::MakeA(int) (mySystem.C:514)
> 1927)
> [6]PETSC ERROR:
> = 32
> ==5821==
> 1927)
> alloc'd
> 1875)
> (dense.c:1858)
> (mpidense.c:1175)
> (mpidense.c:1312)
> (mpidense.c:979)
> 1927)
> [6]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
> Violation, probably memory access out of range
> [6]PETSC ERROR: Try option -start_in_debugger or -
> on_error_attach_debugger
> [6]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal
> [6]PETSC ERROR: or try http://valgrind.org on linux or man
> libgmalloc on Apple to find memory corruption errors
> [6]PETSC ERROR: likely location of problem given in stack below
> [6]PETSC ERROR: --------------------- Stack Frames
> [6]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [6]PETSC ERROR: INSTEAD the line number of the start of the function
> [6]PETSC ERROR: is given.
> [6]PETSC ERROR: [6] MatGetSubMatrix_MPIDense line 218 src/mat/impls/
> dense/mpi/mpidense.c
> [6]PETSC ERROR: [6] MatGetSubMatrix line 5721 src/mat/interface/
> matrix.c
> [6]PETSC ERROR: --------------------- Error Message
> [6]PETSC ERROR: Signal received!
> [6]PETSC ERROR:
> [6]PETSC ERROR: Petsc Release Version 2.3.3, Patch 8, Fri Nov 16
> 17:03:40 CST 2007 HG revision:
> 414581156e67e55c761739b0deb119f7590d0f4b
> [6]PETSC ERROR: See docs/changes/index.html for recent updates.
> [6]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [6]PETSC ERROR: See docs/index.html for manual pages.
> [6]PETSC ERROR:
> [6]PETSC ERROR: /data4/ylu/codes/new/examples/myproj/myproj-dbg on a
> linux named wolf29.cluster1.isl.org by yujie Tue Jan 6 16:20:55 2009
> [6]PETSC ERROR: Libraries linked from /home/yujie/codes/petsc-2.3.3-
> p8/lib/linux
> [6]PETSC ERROR: Configure run at Fri Apr 11 17:24:03 2008
> [6]PETSC ERROR: Configure options --with-mpi-dir=/home/yujie/
> mpich127/ --with-clanguage=C++ --with-debugging=1 --with-shared=1 --
> with-hypre=1 --with-spooles=1 --download-spooles=1 --with-
> superlu_dist=1 --download-superlu_dist=1
> [6]PETSC ERROR:
> [6]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> p6_11637: p4_error: : 59
> rm_l_6_11638: (333.669678) net_send: could not write to fd=5, errno
> = 32
> On Tue, Jan 6, 2009 at 5:52 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>   Looks like this is some old version of PETSc. The line numbers
> don't match PETSc 3.0.0
> Please switch to 3.0.0 and see if the problem occurs and send the
> valgrind output again
> Please switch to petsc-maint at mcs.anl.gov for this.
>   Barry
> I don't see a problem with the MatTranspose_  but there is a bad
> read in the MatGetSubMatrix
> On Jan 6, 2009, at 6:53 PM, Yujie wrote:
> According to Barry's advice, I use Valgrind to check my codes. I
> find there is an problem in MatTranspose_MPIDense(). It breaks my
> codes. The following is the information. could you give me some
> advice? thanks a lot
> ==5821==
> 1927)
> alloc'd
> 1875)
> (dense.c:1858)
> (mpidense.c:1175)
> (mpidense.c:1312)
> (mpidense.c:979)
> 1927)
> Regards,
> Yujie
