MatTranspose_MPIDense illegal read?
Tue Jan 6 19:52:18 CST 2009
    Looks like this is some old version of PETSc. The line numbers
don't match PETSc 3.0.0
Please switch to 3.0.0 and see if the problem occurs and send the
valgrind output again
Please switch to petsc-maint at mcs.anl.gov for this.
    Barry
I don't see a problem with the MatTranspose_  but there is a bad read
in the MatGetSubMatrix
On Jan 6, 2009, at 6:53 PM, Yujie wrote:
> According to Barry's advice, I use Valgrind to check my codes. I
> find there is an problem in MatTranspose_MPIDense(). It breaks my
> codes. The following is the information. could you give me some
> advice? thanks a lot
> ==5821==
> ==5821== Invalid read of size 4
> ==5821== at 0x5143617: MatGetSubMatrix_MPIDense(_p_Mat*, _p_IS*,
> _p_IS*, int, MatReuse, _p_Mat**) (mpidense.c:251)
> ==5821== by 0x50C2D71: MatGetSubMatrix(_p_Mat*, _p_IS*, _p_IS*, int,
> MatReuse, _p_Mat**) (matrix.c:5744)
> ==5821== by 0x805BCE8: mySystem::MakeA(int) (mySystem.C:518)
> ==5821== by 0x80615A6: mySystem::Source(mySystem*, int) (mySystem.C:
> 1927)
> ==5821== by 0x806B5B1: main (myproject.C:293)
> ==5821== Address 0x8f06c64 is 12 bytes after a block of size 472,272
> alloc'd
> ==5821== at 0x401AC01: malloc (vg_replace_malloc.c:207)
> ==5821== by 0x558312D: PetscMallocAlign(unsigned int, int, char
> const*, char const*, char const*, void**) (mal.c:40)
> ==5821== by 0x558DA83: PetscTrMallocDefault(unsigned int, int, char
> const*, char const*, char const*, void**) (mtr.c:194)
> ==5821== by 0x50386A7: MatSeqDenseSetPreallocation_SeqDense (dense.c:
> 1875)
> ==5821== by 0x5038469: MatSeqDenseSetPreallocation(_p_Mat*, double*)
> (dense.c:1858)
> ==5821== by 0x514BC4B: MatMPIDenseSetPreallocation_MPIDense
> (mpidense.c:1175)
> ==5821== by 0x514C889: MatMPIDenseSetPreallocation(_p_Mat*, double*)
> (mpidense.c:1312)
> ==5821== by 0x514AD8B: MatTranspose_MPIDense(_p_Mat*, _p_Mat**)
> (mpidense.c:979)
> ==5821== by 0x50B2D85: MatTranspose(_p_Mat*, _p_Mat**) (matrix.c:3603)
> ==5821== by 0x805BCAA: mySystem::MakeA(int) (mySystem.C:514)
> 1927)
> Regards,
> Yujie
