PetscValidHeaderSpecific()
Tue Jan 6 19:45:36 CST 2009
   If you send your code (and makefile and any data it needs) to petsc-maint at mcs.anl.gov
  and how to run it; we'll run it in
valgrind.
    Frankly cygwin is a terrible system for source code development.
It is really worth your effort to make
your machine dual boot and install linux also; the time you spend
getting linux going will be far more than
gained by the improvement in development time and frustration.
    Barry
If other people need to run your code on Windows, you can still do the
development on Linux and only build
on cygwin when it is very stable.
On Jan 6, 2009, at 6:28 PM, (Rebecca) Xuefei YUAN wrote:
> There is no message coming out when I run with -malloc_debug. I am
> using cygwin, any suggestions on that?
> Thanks!
> Rebecca
> Quoting Barry Smith <bsmith at mcs.anl.gov>:
>>   The most likely cause is memory corruption. The best way to solve
>> this problem is to run on linux using
>> valgrind (valgrind.org), the second best is to run with -malloc_debug
>> and see if any messages come out
>>   Barry
>> On Jan 6, 2009, at 4:44 PM, (Rebecca) Xuefei YUAN wrote:
>>> Hi,
>>> I did have error information as at the end of this email, and I
>>> found the error was a function called PetscValidHeaderSpecific(),
>>> is there anything wrong with it?
>>> Thanks a lot!
>>> R
>>> [0]PETSC ERROR: Invalid argument!
>>> [0]PETSC ERROR: Wrong type of object: Parameter # 1!
>>> [0]PETSC ERROR: ----------------------------------------
>>> [0]PETSC ERROR: Petsc Release Version 3.0.0, Patch 0, Fri Dec 19
>>> 22:02:38 CST 2008
>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>> [0]PETSC ERROR: ./oreggt on a cygwin-c- named YUAN_WORK by
>>> Rebecca  Tue Jan 6 17:29:59 2009
>>> [0]PETSC ERROR: Libraries linked from  /home/Rebecca/soft/
>>> petsc-3.0.0-p0/cygwin-c-debug/lib
>>> [0]PETSC ERROR: Configure run at Mon Jan 5 13:50:14 2009
>>> [0]PETSC ERROR: Configure options --with-cc=gcc  --download-f-blas-
>>> lapack=1 --download-mpich=1 --useThreads=0  --with-shared=0
>>> [0]PETSC ERROR: MatDestroy() line 766 in src/mat/interface/matrix.c
>>> [0]PETSC ERROR: PCDestroy() line 88 in src/ksp/pc/interface/precon.c
>>> [0]PETSC ERROR: KSPDestroy() line 647 in src/ksp/ksp/interface/
>>> itfun.c
>>> [0]PETSC ERROR: SNESDestroy() line 1378 in src/snes/interface/snes.c
>>> [0]PETSC ERROR: PetscObjectDestroy() line 172 in src/sys/objects/
>>> destroy.c
>>> [0]PETSC ERROR: DMMGDestroy() line 220 in src/snes/utils/damg.c
>>> [0]PETSC ERROR: main() line 55 in oreggt.c
>>> application called MPI_Abort(MPI_COMM_WORLD,62) - process
>>> 0[unset]:  aborting job:
>>> application called MPI_Abort(MPI_COMM_WORLD,62) - process 0
> Department of Applied Physics and Applied Mathematics
> Columbia University
> Tel:917-399-8032
> www.columbia.edu/~xy2102
