MatGetLocalSize() and MatDenseGetLocalMatrix()
Yujie recrusader at gmail.com
Tue Jan 6 13:55:41 CST 2009
I am sorry, Matthew. I can't understand what you said. You mean it is not
bug? However, practically, the dimension of local matrix in proc1 is 56*108?
if it is, how to obtain its accurate dimension? thanks a lot.
Yujie
On Tue, Jan 6, 2009 at 11:45 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jan 6, 2009 at 1:43 PM, Yujie <recrusader at gmail.com> wrote:
>> Dear Matthew:
>> Two processors are used. The matrix dimension is 105*108;
>> MatGetOwnershipRange()
>> proc1: 0->56
>> proc2: 56->105
>> Mat->camp.rstart; Mat->cmap.rend
>> proc1: 0->54
>> proc2: 54->108
>> MatGetLocalSize()
>> proc1: row 56 col 54
>> porc2: row 49 col 54
>> proc1: 56*108
>> proc2: 49*108
> Since PETSc matrices are all stored row-wise, even if columns are assigned
> to one process
> for the other, the storage is divided by row. This GetLocalMatrix() returns
> all the rows
> associated with a given process.
>    Matt
>> thanks.
>> Yujie
>> On Tue, Jan 6, 2009 at 11:33 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Tue, Jan 6, 2009 at 11:52 AM, Yujie <recrusader at gmail.com> wrote:
>>>> Dear PETSc developers:
>>>> I am trying to use MatGetArray() and MatSetValues() to combine several
>>>> MPIDense matrices into one matrix. At the beginning, I use
>>>> MatGetOwnershipRange() and Mat->camp.rstart; Mat->cmap.rend (2.3.3-p8
>>>> version) to get the start, end row and column. I can calculate the local
>>>> rows and columns.
>>>> I also use MatGetLocalSize() to confirm the accuracy. However, I always
>>>> find some data loses in the combined matrix.
>>>> And then, I try to use MatDenseGetLocalMatrix() to get the lcoal matrix
>>>> and output it. I find column information by MatGetLocalSize() is not
>>>> consistent with by MatDenseGetLocalMatrix(), is it bug? could you give me
>>>> some advice? thanks a lot.
>>> What information?
>>>   Matt
>>>> Regards,
>>>> Yujie
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090106/152ca0ca/attachment.htm>
