further about MatGetSubMatrix() Re: distribution of submatrix and subvector Re: how to extract a subvector?
Yujie recrusader at gmail.com
Sat Jan 3 12:52:42 CST 2009
Dear Matthew:
I have checked the description of MatGetSubMatrix() and ISAllGather(). I am
wondering if isrow is created by MPI_COMM, does it work when iscol is
obtained based on PETSC_COMM_SELF? thanks.
MatGetSubMatrix(Mat mat,IS isrow,IS iscol,PetscInt csize,MatReuse cll,Mat
*newmat)
Yujie
On Fri, Jan 2, 2009 at 6:20 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jan 2, 2009 at 7:58 PM, Yujie <recrusader at gmail.com> wrote:
>> Dear Barry:
>> When using MatGetSubmatrix() to get a submatrix in parallel mode, to my
>> knowledge, this function will exact the rows and cols for submatrix. This
>> submatrix is not redistributed. For example, if there is zero row and zero
>> col in a process, the row and col of this submatrix in this process are
>> zero, right?
>> However, to get a subvector using Vec scatter, the user needs to create
>> the subvector using MPI_COMM, that is new distribution for subvector is
>> generated. Just regarding only rows or cols of the submatrix and the
>> subvector, their distribution should be different even if using the same
>> index to get them, right? thanks a lot.
> No. They work exactly the same way.
>   Matt
>> Regards,
>> Yujie
>> On Fri, Jan 2, 2009 at 5:15 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>   The ix and iy are always global indices based on where the vector
>>> lives.
>>>   If you are going from a parallel to parallel vector then both indices
>>> are "global"
>>>  Barry
>>> On Jan 2, 2009, at 2:21 PM, Yujie wrote:
>>>  Dear Barry:
>>>> I have a new question about the parameter "iy"(new index set of
>>>> subvector). To parallel vector, how to provide "ix" and "iy"?
>>>> Just providing the local index subset for "ix" and "iy"? if it is, it is
>>>> a little difficult to let the local vector know its global position in the
>>>> new subvector? If the user needs to provide the global position of local
>>>> vector for "iy". some MPI communication should be needed, it looks like not
>>>> a good method. In exacting submatrix, the function hides this problem. could
>>>> you give me any comments? thanks a lot.
>>>> Regards,
>>>> Yujie
>>>> On Fri, Jan 2, 2009 at 11:46 AM, Barry Smith <bsmith at mcs.anl.gov>
>>>> wrote:
>>>>  VecScatter is for this purpose.
>>>>  Rational: extracting subparts of vectors for ghost points etc takes
>>>> place many times in a simulation; maybe millions.
>>>> Thus separating it into a set-up followed by many uses is a  worthwhile
>>>> optimization. Extracting submatrices occur
>>>> much less often in a simulation, maybe tens, hundreds or thousands of
>>>> times so it is not worth the extra complexity
>>>> of having separate set-up followed by many uses. One could argue that
>>>> uniformity of design means we should have
>>>> handled matrices with a MatScatter concept to parallel the Vec approach,
>>>> but it is too late now :-).
>>>>  Barry
>>>> On Jan 2, 2009, at 1:41 PM, Yujie wrote:
>>>> Like MatGetSubMatrix(), whether is there a function to get a subvector
>>>> in parallel mode? I have checked some scatter functios, they don't likely
>>>> work. thanks a lot.
>>>> Regards,
>>>> Yujie
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090103/04814af8/attachment.htm>
