how to extract a subvector?
Fri Jan 2 19:15:14 CST 2009
    The ix and iy are always global indices based on where the vector
lives.
    If you are going from a parallel to parallel vector then both
indices are "global"
   Barry
On Jan 2, 2009, at 2:21 PM, Yujie wrote:
> Dear Barry:
> I have a new question about the parameter "iy"(new index set of
> subvector). To parallel vector, how to provide "ix" and "iy"?
> Just providing the local index subset for "ix" and "iy"? if it is,
> it is a little difficult to let the local vector know its global
> position in the new subvector? If the user needs to provide the
> global position of local vector for "iy". some MPI communication
> should be needed, it looks like not a good method. In exacting
> submatrix, the function hides this problem. could you give me any
> comments? thanks a lot.
> Regards,
> Yujie
> On Fri, Jan 2, 2009 at 11:46 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>   VecScatter is for this purpose.
>   Rational: extracting subparts of vectors for ghost points etc
> takes place many times in a simulation; maybe millions.
> Thus separating it into a set-up followed by many uses is a
> worthwhile optimization. Extracting submatrices occur
> much less often in a simulation, maybe tens, hundreds or thousands
> of times so it is not worth the extra complexity
> of having separate set-up followed by many uses. One could argue
> that uniformity of design means we should have
> handled matrices with a MatScatter concept to parallel the Vec
> approach, but it is too late now :-).
>   Barry
> On Jan 2, 2009, at 1:41 PM, Yujie wrote:
> Like MatGetSubMatrix(), whether is there a function to get a
> subvector in parallel mode? I have checked some scatter functios,
> they don't likely work. thanks a lot.
> Regards,
> Yujie
