MatCreateMPIAIJWithSplitArrays
Panyasantisuk Jarunan Jarunan.Panyasantisuk at eleves.ec-nantes.fr
Thu Jan 15 09:42:40 CST 2009
When I create a matrix with MatCreateMPIAIJWithSplitArrays, as it
doesn't copy the values so I have to use MatSetValues to set the
internal value?
Jarunan PANYASANTISUK
MSc. in Computational Mechanics
Erasmus Mundus Master Program
Ecole Centrale de Nantes
1, rue de la noë, 44321 NANTES, FRANCE
Barry Smith <bsmith at mcs.anl.gov> a écrit :
>    You should be able to use MatCreateMPIAIJWithSplitArrays(),
> MatCreateMPIAIJWithArrays() or MatMPIAIJSetPreallocationCSR()
> from Fortran. Are you using PETSc 3.0.0?
>    The arguments for MatCreateMPIAIJWithArrays() or
> MatMPIAIJSetPreallocationCSR() have the same meaning
> (in fact MatCreateMPIAIJWithArrays() essentially calls
> MatCreateMPIAIJWithArrays()).
>    Barry
> On Jan 14, 2009, at 7:38 AM, Panyasantisuk Jarunan wrote:
>> Oh, I could not use MatCreateMPIAIJWithArrays either but the
>> mechanism below works.
>>     call MatCreate(PETSC_COMM_WORLD,D,ierr)
>>     call MatSetSizes(D,N,N,PETSC_DETERMINE,PETSC_DETERMINE,
>>    $     ierr)
>>     call MatSetType(D,MATMPIAIJ,ierr) ! to set type a parallel matrix
>>     call MatSetFromOptions(D,ierr)
>>     call MatMPIAIJSetPreallocationCSR(D,pointer,Column,v,ierr)
>> Where pointer is start-row indices a
>>     Column is local column indices
>>     v is value
>> Is there the different beteween the start-row indices in
>> MatMPIAIJSetPreallocationCSR and row indices in
>> MatCreateMPIAIJWithArrays ?
>> Regards,
>> Jarunan
>> Hello,
>> To define a matrix with arrays, I cannot use
>> MatCreateMPIAIJWithSplitArrays in my program which is written in
>> Fortran:
>>     call MatCreateMPIAIJWithSplitArrays(PETSC_COMM_WORLD,N,N,
>>    $     PETSC_DETERMINE,PETSC_DETERMINE,pointer,column,v,opointer,
>>    $     oColumn,ov,D,ierr)
>> The error is
>> F:246: undefined reference to `matcreatempiaijwithsplitarrays_'
>> I could use MatCreateMPIAIJWithArrays but the off diagonal values
>> are missing with this command.
>> I would be appreciate for any advice. Thank you before hand.
>> Regards,
>> Jarunan
