command line option "-sub_pc_factor_levels 1" does not work in fortran
hxie at umn.edu hxie at umn.edu
Tue Dec 8 16:29:23 CST 2009
I want to change the ilu levels for block jacobi method. What is the
command line option for it? Or should I use "PCFactorSetLevels" in the
code? The "-sub_pc_factor_levels 1" does not work in fortran. Thanks.
Bests,
Hui
