Some strange results running in PETSc.
(Rebecca) Xuefei YUAN xy2102 at columbia.edu
Wed Apr 29 22:18:06 CDT 2009
I am running some codes and stores the solution in the text file.
However, I found that some results are wired in the sense that some
processors are "eating" my (i,j) index and the corresponding solution.
For example, the solution at time step =235 on processor 6 is right,
but at time step = 236 on processor 6, one grid solution is missing
and thus the order of the index is wrong.
In the attached two files:
hp.solution.dt0.16700.n90.t235.p6 (right one)
hp.solution.dt0.16700.n90.t236.p6 (wrong one)
for example,
in hp.solution.dt0.16700.n90.t235.p6 (right one)
i      j
50 14 3.3212491928636803e-02 7.2992225179014901e-03
2.9841295384404947e+00 2.2004855368148415e-02
51 14 4.0287965701667774e-02 2.5401878231124070e-03
2.9201873761746322e+00 2.6251864239477816e-02
52 14 4.7084950235070790e-02 -1.5367647745423544e-03
2.8460826176461214e+00 3.1550405800570377e-02
53 14 5.3394938807608198e-02 -3.8189091837479271e-03
2.7618414550374171e+00 3.4078755072804334e-02
however, in hp.solution.dt0.16700.n90.t236.p6 (wrong one)
i      j
50 14 3.1239406700376452e-02 8.5179559039992043e-03
2.9840003096148520e+00 2.1760859158622522e-02
51 14 3.8032143218986063e-02 3.6341965920997721e-03
2.9198035731818854e+00 2.6200771510346648e-02
53 14 5.0661309132451274e-02 -2.9274557377189617e-03
2.7606822480069755e+00 3.4021016413777964e-02
54 14 5.6049570141121191e-02 -2.8111244430837979e-03
2.6669503598276267e+00 3.8855104759650566e-02
the (i,j) = (52,14) is missing and as a result, one grid point
solution is missing.
I did not understand how this happens and why this happens?
Any ideas?
Thanks very much!
Cheers,
Rebecca
Department of Applied Physics and Applied Mathematics
Columbia University
Tel:917-399-8032
www.columbia.edu/~xy2102
46 12 8.6953221505124516e-03 2.0605847174523028e-02 2.9607903988665032e+00 4.9976731491140052e-03
47 12 1.7514395632452152e-02 1.7843969816173071e-02 2.9402412885707143e+00 9.7114965432256537e-03
48 12 2.6478777014489099e-02 1.3643571973255383e-02 2.9066372480894351e+00 1.5562306706129153e-02
49 12 3.5589716228136017e-02 8.7845608901538207e-03 2.8593225581624639e+00 1.9131705483206349e-02
50 12 4.4648511105922987e-02 4.0427364020778882e-03 2.8001461138919930e+00 2.6529018238762227e-02
51 12 5.3389759546595618e-02 1.1497620904368645e-03 2.7278833359269510e+00 3.1473181267120912e-02
52 12 6.1638327210051774e-02 1.0290723419584355e-03 2.6433121163772908e+00 3.4052125788813135e-02
53 12 6.8908915297550527e-02 3.9751048206720764e-03 2.5483390260232524e+00 4.7237041818613525e-02
54 12 7.4892358235516196e-02 9.8052096613123040e-03 2.4415020843540391e+00 5.7403008206305749e-02
55 12 7.9819204288899617e-02 1.6594551477715502e-02 2.3233991271715291e+00 4.6511455455329691e-02
56 12 8.3737978143752237e-02 2.1326503890894313e-02 2.2002058515721505e+00 3.0320442405839150e-02
57 12 8.6198605640352727e-02 2.1945671528569004e-02 2.0789729377765296e+00 3.4491799076114889e-02
58 12 8.6983790203463029e-02 1.8173382004082844e-02 1.9630518079080044e+00 5.7341718107343280e-02
59 12 8.6263182600523250e-02 1.0887053709102965e-02 1.8521303092803896e+00 7.9624750636460628e-02
60 12 8.4600391426024907e-02 1.1301469113017583e-03 1.7450752493699524e+00 8.8137868580738063e-02
61 12 8.2348058491617290e-02 -1.0263254751762367e-02 1.6415610269999552e+00 8.4888500652429241e-02
62 12 7.9489027725015732e-02 -2.2516878788224840e-02 1.5419858772953983e+00 7.8721724219649236e-02
63 12 7.5877719097376631e-02 -3.4734469427269335e-02 1.4466531317263069e+00 7.6214937893437001e-02
64 12 7.1420495932718500e-02 -4.5983362980324759e-02 1.3553969299960216e+00 7.7335548348328786e-02
65 12 6.6189165845669085e-02 -5.5541991365218993e-02 1.2678370636381959e+00 7.8293867336053827e-02
66 12 6.0482800577468548e-02 -6.3176784865969171e-02 1.1837485624394763e+00 7.6385265197791222e-02
67 12 5.4750682728317096e-02 -6.9316546271342788e-02 1.1031236660506867e+00 7.1277608314767135e-02
46 13 7.4173593520649320e-03 2.1059876847711278e-02 3.0438055164620628e+00 4.7241131430010904e-03
47 13 1.4972377718444908e-02 1.8816488989064423e-02 3.0242636110527799e+00 9.1353983931045223e-03
48 13 2.2750673670075747e-02 1.5157025345777946e-02 2.9923891595228564e+00 1.4167088607220435e-02
49 13 3.0718657490524028e-02 1.0600000227029758e-02 2.9479533715613080e+00 1.8863832484416199e-02
50 13 3.8797009150328542e-02 5.6236647397885772e-03 2.8915806108375519e+00 2.2824015258721766e-02
51 13 4.6713353522402294e-02 1.1605926706015146e-03 2.8241291897867127e+00 2.9470725425542091e-02
52 13 5.4232096883532144e-02 -1.4218344480102015e-03 2.7449793572205539e+00 3.2798117443219907e-02
53 13 6.1130713332375339e-02 -1.3585181953299384e-03 2.6553239019104944e+00 3.6609242943439611e-02
54 13 6.6992504240975845e-02 1.6566141889439447e-03 2.5560875921619468e+00 4.8651629941571010e-02
55 13 7.1623973972656615e-02 7.2066172542624976e-03 2.4463621299755798e+00 5.6592427187780472e-02
56 13 7.5230192975498045e-02 1.3508223739846155e-02 2.3273752739331983e+00 4.7685177964185387e-02
57 13 7.7879012145652543e-02 1.8062141487968773e-02 2.2043151597803350e+00 3.3500006044831276e-02
58 13 7.9275481924596811e-02 1.9042187900578277e-02 2.0831962289633976e+00 3.3930912642814955e-02
59 13 7.9247782381475743e-02 1.5969025037424697e-02 1.9674977383490257e+00 5.0948772465235430e-02
60 13 7.7857962162705810e-02 9.4378828913587176e-03 1.8574863724033923e+00 7.2160439939907992e-02
61 13 7.5564903554000667e-02 3.9311235591571534e-04 1.7521008088233945e+00 8.4412870052469627e-02
62 13 7.2729791800087928e-02 -1.0262504574496926e-02 1.6505580991621174e+00 8.4379572019936663e-02
63 13 6.9441911440407331e-02 -2.1692522440963560e-02 1.5528352394804574e+00 7.7481419341905319e-02
64 13 6.5625111718553050e-02 -3.3049031230736714e-02 1.4592331092983732e+00 7.1000256610966594e-02
65 13 6.1135917079909716e-02 -4.3516341556941028e-02 1.3698897947960931e+00 6.8164033228793677e-02
66 13 5.5984430468646929e-02 -5.2518935705375192e-02 1.2846905692704527e+00 6.8192379941696024e-02
67 13 5.0456445567035914e-02 -6.0003289473553462e-02 1.2034179972532224e+00 6.8572250390128042e-02
46 14 6.2125310352920942e-03 2.0303946122167457e-02 3.1281391934751750e+00 4.3418548964642848e-03
47 14 1.2586252994141551e-02 1.8526081233266944e-02 3.1098454935089426e+00 8.9060293648175973e-03
48 14 1.9230946043577560e-02 1.5667372453989855e-02 3.0794176943161435e+00 1.3115057054418081e-02
49 14 2.6137774778200437e-02 1.1810351136806422e-02 3.0375174049882485e+00 1.8087048754774859e-02
50 14 3.3212491928636803e-02 7.2992225179014901e-03 2.9841295384404947e+00 2.2004855368148415e-02
51 14 4.0287965701667774e-02 2.5401878231124070e-03 2.9201873761746322e+00 2.6251864239477816e-02
52 14 4.7084950235070790e-02 -1.5367647745423544e-03 2.8460826176461214e+00 3.1550405800570377e-02
53 14 5.3394938807608198e-02 -3.8189091837479271e-03 2.7618414550374171e+00 3.4078755072804334e-02
54 14 5.8993292313748183e-02 -3.5973792455875567e-03 2.6685349927998416e+00 3.8408227574764739e-02
55 14 6.3556335349961954e-02 -6.2431637367217803e-04 2.5666275536315712e+00 4.8699089040917742e-02
56 14 6.6964056267884084e-02 4.5769367377603920e-03 2.4557353749765953e+00 5.5250177879654923e-02
57 14 6.9383096110104403e-02 1.0443700417892785e-02 2.3372460787617091e+00 4.8877265509441860e-02
58 14 7.0902882912434767e-02 1.4901150217599933e-02 2.2153762731957523e+00 3.6855855444881423e-02
59 14 7.1371437986785607e-02 1.6309046491044948e-02 2.0952150868451325e+00 3.3767321347237748e-02
60 14 7.0669455361377170e-02 1.4022514079635867e-02 1.9802548348082920e+00 4.4183070822277598e-02
61 14 6.8778625694252790e-02 8.3491333919763697e-03 1.8713681248889604e+00 6.2122972249850195e-02
62 14 6.6020744812228985e-02 9.3214254594525453e-05 1.7678740540400675e+00 7.6623706282128889e-02
63 14 6.2682284726107512e-02 -9.7792451167304662e-03 1.6688065675718022e+00 8.1415567216948037e-02
64 14 5.8918721723525268e-02 -2.0302586431406405e-02 1.5736941621604550e+00 7.7500219992702721e-02
65 14 5.4746595093657431e-02 -3.0579454642138081e-02 1.4825643820257655e+00 6.9762389143182515e-02
66 14 5.0069730858363332e-02 -3.9888642901338277e-02 1.3955927459608877e+00 6.2758970275432674e-02
67 14 4.4933663450095848e-02 -4.7891116689763653e-02 1.3128772446257440e+00 5.8682027004382027e-02
46 15 5.1152952775922033e-03 1.8659378110024907e-02 3.2140271070913005e+00 4.1540349709897912e-03
47 15 1.0407156273095077e-02 1.7326664719003650e-02 3.1967057763255800e+00 8.4306957061432188e-03
48 15 1.5988622567598428e-02 1.5168445877281743e-02 3.1679442576225614e+00 1.2719379076289393e-02
49 15 2.1885568217009564e-02 1.2174941867328717e-02 3.1281577535354508e+00 1.7001405158051222e-02
50 15 2.8005157584934003e-02 8.4234346635273499e-03 3.0777427119831637e+00 2.1535344884361880e-02
51 15 3.4203628631048706e-02 4.1201527991218930e-03 3.0170732085592578e+00 2.5092419266711505e-02
52 15 4.0273023892509745e-02 -3.0905470037058879e-04 2.9469864247848712e+00 2.9151288534464047e-02
53 15 4.5966726241029668e-02 -4.0006666181612452e-03 2.8678393242058098e+00 3.3130278884574968e-02
54 15 5.1104650994780447e-02 -6.0041424552807693e-03 2.7800364642676412e+00 3.5223124979544898e-02
55 15 5.5488243850781153e-02 -5.6728228381646593e-03 2.6844283422931334e+00 3.9372064188177118e-02
56 15 5.8877431019381893e-02 -2.8373977451194481e-03 2.5813303997207036e+00 4.7735205473457727e-02
57 15 6.1192754404677731e-02 1.9625744957038923e-03 2.4707229892338156e+00 5.3395658748910058e-02
58 15 6.2559399840932478e-02 7.4029841945239131e-03 2.3539122221120694e+00 4.9631397477652224e-02
59 15 6.3085762963691172e-02 1.1767920074159980e-02 2.2342302605464366e+00 4.0074274113849645e-02
60 15 6.2738583370051323e-02 1.3595809964949298e-02 2.1158922086823080e+00 3.4544843870994241e-02
61 15 6.1459495497541553e-02 1.2132218698963734e-02 2.0022478956425349e+00 3.8648370005537683e-02
62 15 5.9191014617697386e-02 7.4369212481993083e-03 1.8946927916820802e+00 5.1280094143650111e-02
63 15 5.6112883035391553e-02 1.5241042460865118e-04 1.7931192080227514e+00 6.5078275199232719e-02
64 15 5.2381914480018284e-02 -8.7393573351747279e-03 1.6966990995460491e+00 7.3703171614088514e-02
65 15 4.8154561274024253e-02 -1.8158186214249080e-02 1.6047042570277603e+00 7.4757596569215323e-02
66 15 4.3514236192847160e-02 -2.7140068841868543e-02 1.5167924507932848e+00 6.9645510071157046e-02
67 15 3.8487646056039965e-02 -3.5050041703896445e-02 1.4329030412257056e+00 6.1796068583530220e-02
46 16 4.1121613287546767e-03 1.6611727971503738e-02 3.3012373876010765e+00 4.0112149671078772e-03
47 16 8.4072155839625025e-03 1.5640948062718176e-02 3.2848185807655312e+00 8.0389858799836296e-03
48 16 1.3009529873836844e-02 1.4026826818067700e-02 3.2576849926871678e+00 1.2267366461203941e-02
49 16 1.7952728506840557e-02 1.1775392085978324e-02 3.2200224311420773e+00 1.6380610929632368e-02
50 16 2.3173517317309104e-02 8.8396949162233354e-03 3.1723098667280469e+00 2.0617505845510527e-02
51 16 2.8527375873014901e-02 5.2605331108324270e-03 3.1149331904123927e+00 2.4642039277569559e-02
52 16 3.3844169479655781e-02 1.2062688978583447e-03 3.0484729299533981e+00 2.7964409658875373e-02
53 16 3.8918292620302095e-02 -2.8748849238108124e-03 2.9736549446978735e+00 3.1505366881226446e-02
54 16 4.3547349660752313e-02 -6.2069009445611893e-03 2.8909473772084544e+00 3.4424485208683749e-02
55 16 4.7580424685808739e-02 -7.9710880751985153e-03 2.8009205099100662e+00 3.6154412382339962e-02
56 16 5.0854081627286961e-02 -7.6092730545798135e-03 2.7042647267665645e+00 3.9641542152399581e-02
57 16 5.3194487235788138e-02 -5.0173104951803374e-03 2.6012868465831764e+00 4.6092263504384168e-02
58 16 5.4544418744086581e-02 -6.8981101735996983e-04 2.4921828963517614e+00 5.1006910369826138e-02
59 16 5.4994924553140458e-02 4.2836327580780377e-03 2.3780796826182380e+00 4.9514823037830176e-02
60 16 5.4666172261284576e-02 8.5004902840890417e-03 2.2615335099041989e+00 4.2636775110839707e-02
61 16 5.3609165992374738e-02 1.0679834551897555e-02 2.1459324006490923e+00 3.6227663615146233e-02
62 16 5.1824250947414448e-02 1.0027817808510680e-02 2.0343188029423711e+00 3.5426258051869976e-02
63 16 4.9248691299402139e-02 6.4274458142425410e-03 1.9284341544992951e+00 4.1920964867417754e-02
64 16 4.5942736420817219e-02 3.6482770074813435e-04 1.8287654150660164e+00 5.2078611259451145e-02
65 16 4.1929143621165149e-02 -7.2191885007406413e-03 1.7348739413467118e+00 6.1426997674065266e-02
66 16 3.7317264247106942e-02 -1.5218834824136813e-02 1.6460751828468192e+00 6.6340158974418473e-02
67 16 3.2216964534058742e-02 -2.2669907423239363e-02 1.5617743688866514e+00 6.5718965253840023e-02
46 17 3.2038513402595833e-03 1.4549363688928604e-02 3.3895591676663472e+00 3.8740372261070587e-03
47 17 6.5893010911466827e-03 1.3832948394557329e-02 3.3740799785352897e+00 7.8047258334290430e-03
48 17 1.0288153920761848e-02 1.2627273070096253e-02 3.3484604158029749e+00 1.1814964845215372e-02
49 17 1.4343562544311081e-02 1.0917642310925266e-02 3.3129302217397250e+00 1.5915837352799615e-02
50 17 1.8711069907365707e-02 8.6603810569449227e-03 3.2678224968534835e+00 1.9891857112843046e-02
51 17 2.3268354328054120e-02 5.8075366064755298e-03 3.2136008840805963e+00 2.3873438109450550e-02
52 17 2.7851442490967895e-02 2.3902533780137251e-03 3.1507328506174890e+00 2.7425971912980490e-02
53 17 3.2289470499939563e-02 -1.4108553486720968e-03 3.0798629197810201e+00 3.0454281997189366e-02
54 17 3.6401531810566365e-02 -5.1542768558244315e-03 3.0016709734921223e+00 3.3364940344086241e-02
55 17 4.0026666380262227e-02 -8.1642473948382813e-03 2.9167297948312720e+00 3.5485725237048169e-02
56 17 4.3040698476333121e-02 -9.7514986799021215e-03 2.8256685511253132e+00 3.6823497285884521e-02
57 17 4.5315242054961340e-02 -9.4553091544438365e-03 2.7290964170680425e+00 3.9412667748337134e-02
58 17 4.6728186094146799e-02 -7.2080798896910379e-03 2.6273598240592557e+00 4.4054673737077221e-02
59 17 4.7238582365894982e-02 -3.4265439603308372e-03 2.5207756866934345e+00 4.8132749440320768e-02
60 17 4.6915167308037457e-02 1.0173022367524662e-03 2.4102691717707518e+00 4.8264378889040602e-02
61 17 4.5878458913814729e-02 4.9914096968149378e-03 2.2977472609152954e+00 4.3979159143593703e-02
62 17 4.4224680130988188e-02 7.3990129011475029e-03 2.1858328774551228e+00 3.8173580608216115e-02
63 17 4.1994820361455860e-02 7.4827953801520318e-03 2.0771305343119466e+00 3.4563297534431575e-02
64 17 3.9137257641992704e-02 5.0370874042866597e-03 1.9734992097644621e+00 3.5730952569924916e-02
65 17 3.5631725273507026e-02 4.3449677264763162e-04 1.8758828301938326e+00 4.0744339317557048e-02
66 17 3.1408151509453426e-02 -5.4777200198948585e-03 1.7843301358141830e+00 4.7520639963472604e-02
67 17 2.6522238334985564e-02 -1.1679511023747726e-02 1.6984415129734605e+00 5.3018341714655810e-02
46 18 2.3843828669610156e-03 1.2660978178025983e-02 3.4789271288679227e+00 3.7918342793510783e-03
47 18 4.9450889525803707e-03 1.2132860447939984e-02 3.4643510317225061e+00 7.6421135667516567e-03
48 18 7.8140679661203652e-03 1.1226229835357066e-02 3.4401964470811213e+00 1.1541284520763247e-02
49 18 1.1046618013063213e-02 9.9060143131185548e-03 3.4067015198600039e+00 1.5506589806688502e-02
50 18 1.4612750988423856e-02 8.1374440503600414e-03 3.3641562260547460e+00 1.9422558129474219e-02
51 18 1.8413498469032674e-02 5.8727315303511605e-03 3.3129651226979617e+00 2.3183654657968313e-02
52 18 2.2301622623293011e-02 3.0835195724965925e-03 3.2536020585164382e+00 2.6772033944297578e-02
53 18 2.6116220201990684e-02 -1.8279689744549508e-04 3.1866007696746581e+00 2.9872680865316317e-02
54 18 2.9701667884207642e-02 -3.7316976800115241e-03 3.1126129141969376e+00 3.2513413034807800e-02
55 18 3.2907391541621034e-02 -7.1583115429751567e-03 3.0323072668050601e+00 3.4808631252509027e-02
56 18 3.5606527510435450e-02 -9.8939725694922511e-03 2.9463146261644657e+00 3.6319829721286813e-02
57 18 3.7698663737262605e-02 -1.1375390742749276e-02 2.8552820963069059e+00 3.7239861983610650e-02
58 18 3.9088465706309777e-02 -1.1228746132927958e-02 2.7597873686482539e+00 3.8889025411047565e-02
59 18 3.9695256409507204e-02 -9.4009394189014297e-03 2.6602313542384337e+00 4.1895974993005257e-02
60 18 3.9495309259367679e-02 -6.2230345830911723e-03 2.5569963966181226e+00 4.4965631490782157e-02
61 18 3.8545039913546152e-02 -2.3786535532725776e-03 2.4508312675303316e+00 4.5920514488069615e-02
62 18 3.6954074865480128e-02 1.2282016341536312e-03 2.3431267665259212e+00 4.3758560412907668e-02
63 18 3.4827220456812864e-02 3.6945661465787663e-03 2.2358327801611484e+00 3.9451292942136867e-02
64 18 3.2218910695365657e-02 4.3660320425317227e-03 2.1310490517969525e+00 3.5111254516543990e-02
65 18 2.9087342227999129e-02 3.0455444688651813e-03 2.0305282973571783e+00 3.2918417721830844e-02
66 18 2.5372232775870272e-02 4.3101617223550806e-05 1.9354486875268957e+00 3.3273427758987784e-02
67 18 2.0969446360974874e-02 -3.9151705864842639e-03 1.8462670595978425e+00 3.5839853074825130e-02
46 19 1.6512843261320075e-03 1.0987872164888977e-02 3.5693114120600948e+00 3.7544453550501099e-03
47 19 3.4693828934049794e-03 1.0614470512646424e-02 3.5555847621812378e+00 7.5448521170096428e-03
48 19 5.5832878553496159e-03 9.9412650542773581e-03 3.5328411070743782e+00 1.1389274895471794e-02
49 19 8.0560404265094324e-03 8.9169703548363649e-03 3.5012842989918398e+00 1.5246580463137240e-02
50 19 1.0874798910797465e-02 7.5006175557548070e-03 3.4611993753262835e+00 1.9078439557839770e-02
51 19 1.3960170247446628e-02 5.6628766607884507e-03 3.4129406099981541e+00 2.2748376850992687e-02
52 19 1.7187306926990015e-02 3.3791114984346986e-03 3.3569501463910090e+00 2.6189271201973383e-02
53 19 2.0408118329521163e-02 6.4893557402087099e-04 3.2937280845971824e+00 2.9321606718930526e-02
54 19 2.3476723238065832e-02 -2.4602876499539316e-03 3.2238399203920238e+00 3.1962958457161156e-02
55 19 2.6258295464776520e-02 -5.7576796941004914e-03 3.1479284673536454e+00 3.4156911956077854e-02
56 19 2.8630619370958902e-02 -8.8930690252339677e-03 3.0666518643046277e+00 3.5892661056604852e-02
57 19 3.0493738278774083e-02 -1.1403520667650087e-02 2.9806615465117541e+00 3.6918478010249958e-02
58 19 3.1769633521921414e-02 -1.2838304360500291e-02 2.8906014649494733e+00 3.7430068396673274e-02
59 19 3.2392878898576796e-02 -1.2895369907254324e-02 2.7970441000103028e+00 3.8231054024247216e-02
60 19 3.2317458564871615e-02 -1.1528530737544909e-02 2.7004400730470790e+00 3.9850014504588943e-02
61 19 3.1538209536514525e-02 -8.9913866493091833e-03 2.6012104705787098e+00 4.1788846857990419e-02
62 19 3.0106151848055710e-02 -5.8169296010834618e-03 2.4999744392347112e+00 4.2824771525379189e-02
63 19 2.8111751824499116e-02 -2.7099067826484723e-03 2.3977370098242989e+00 4.1999743689251690e-02
64 19 2.5642115166966899e-02 -3.7583093927085479e-04 2.2959013817621652e+00 3.9311086761425744e-02
65 19 2.2739024932534879e-02 6.9031725796892798e-04 2.1960607660111831e+00 3.5593548755216170e-02
66 19 1.9360984539962538e-02 3.6977888255263831e-04 2.0997081168528346e+00 3.2154276329086920e-02
67 19 1.5438050100429968e-02 -1.0432301873896661e-03 2.0080189220035769e+00 2.9631505848896855e-02
46 20 1.0005713393943312e-03 9.5017081123285156e-03 3.6606778948685812e+00 3.7416489300894046e-03
47 20 2.1556139405973940e-03 9.2610489425346554e-03 3.6477633247626944e+00 7.5085693396003093e-03
48 20 3.5885938883311297e-03 8.7880043044545279e-03 3.6263631596267261e+00 1.1309641194272810e-02
49 20 5.3667732922661367e-03 8.0102175511010849e-03 3.5966615908351534e+00 1.5115097149696225e-02
50 20 7.4924739787415977e-03 6.8735127555147619e-03 3.5589207954479325e+00 1.8863857888042439e-02
51 20 9.9068107944864647e-03 5.3529476751576887e-03 3.5134740087135223e+00 2.2477537729162646e-02
52 20 1.2506075993609781e-02 3.4444756299246053e-03 3.4607226745356003e+00 2.5837693062659404e-02
53 20 1.5160874077946692e-02 1.1524882969926673e-03 3.4011375846729339e+00 2.8887408479528413e-02
54 20 1.7734940457716470e-02 -1.4990556993727258e-03 3.3352386564920229e+00 3.1543630638170637e-02
55 20 2.0100928465037738e-02 -4.4339065447279637e-03 3.2636019595819645e+00 3.3717558182568816e-02
56 20 2.2145164753640190e-02 -7.4804875903483848e-03 3.1868512001165499e+00 3.5441880155073519e-02
57 20 2.3769428022307568e-02 -1.0349759450154568e-02 3.1056273903527054e+00 3.6673532122603443e-02
58 20 2.4896339715789952e-02 -1.2675191999544918e-02 3.0205737284853935e+00 3.7292538535201189e-02
59 20 2.5468985979643841e-02 -1.4100081990934616e-02 2.9323189951321198e+00 3.7427685599965600e-02
60 20 2.5448607918788255e-02 -1.4385567397833704e-02 2.8414354097290775e+00 3.7556283499316126e-02
61 20 2.4817783643438188e-02 -1.3490546586533239e-02 2.7484076422565842e+00 3.8082260735718951e-02
62 20 2.3589343336608590e-02 -1.1611993935377100e-02 2.6536848254584062e+00 3.8935620038885489e-02
63 20 2.1811762687040492e-02 -9.1584992822167973e-03 2.5577995428625764e+00 3.9535705699374889e-02
64 20 1.9552560718246830e-02 -6.6616023925910534e-03 2.4614977563818163e+00 3.9231839964941270e-02
65 20 1.6868207868199737e-02 -4.6256110695646292e-03 2.3657686281406716e+00 3.7680740280574096e-02
66 20 1.3771923064182467e-02 -3.3629764370108782e-03 2.2717690628115208e+00 3.4992575818894436e-02
67 20 1.0216563831813628e-02 -2.8773280983627786e-03 2.1806570915446502e+00 3.1680335175008734e-02
46 21 4.2819159687512460e-04 8.1632007249548867e-03 3.7529903834448159e+00 3.7423609631461038e-03
47 21 9.9711160580639069e-04 8.0361394988281831e-03 3.7408544465593803e+00 7.5017491952824259e-03
48 21 1.8223463049841296e-03 7.7391232489513418e-03 3.7207385811780820e+00 1.1276720360426545e-02
49 21 2.9729908670854291e-03 7.1809536434441065e-03 3.6928128968565739e+00 1.5044619806378935e-02
50 21 4.4630211842279621e-03 6.2898530592735060e-03 3.6573153126998164e+00 1.8745564376663873e-02
51 21 6.2530378926498095e-03 5.0327232191291708e-03 3.6145560350050006e+00 2.2306723048093197e-02
52 21 8.2606063458683775e-03 3.4143364240138180e-03 3.5649083315155745e+00 2.5637044991408991e-02
53 21 1.0375890873171322e-02 1.4584462825118164e-03 3.5088085173247681e+00 2.8643640582957056e-02
54 21 1.2477040328430030e-02 -8.0788691088751207e-04 3.4467451721111528e+00 3.1274776134106071e-02
55 21 1.4443655042179667e-02 -3.3475041858781873e-03 3.3792493006270390e+00 3.3464274062126993e-02
56 21 1.6166861381571758e-02 -6.0878453757704206e-03 3.3068913780283182e+00 3.5180477777681421e-02
57 21 1.7552281639891781e-02 -8.8841019430742352e-03 3.2302718610025165e+00 3.6437506196775833e-02
58 21 1.8522518692212671e-02 -1.1508044131585694e-02 3.1500059790290980e+00 3.7214981162674035e-02
59 21 1.9020137500286093e-02 -1.3673284098105828e-02 3.0667102983264090e+00 3.7459322958210216e-02
60 21 1.9008228804481608e-02 -1.5105050505846495e-02 2.9809901134630730e+00 3.7259219685928026e-02
61 21 1.8471089387219392e-02 -1.5617600902148483e-02 2.8934057046210779e+00 3.6879631284435256e-02
62 21 1.7413686408023165e-02 -1.5182594919430080e-02 2.8044607964052970e+00 3.6617815353005692e-02
63 21 1.5863615239819974e-02 -1.3952505300488589e-02 2.7146151715551481e+00 3.6563304315398518e-02
64 21 1.3865327635428144e-02 -1.2234280411652334e-02 2.6243556996642896e+00 3.6521224130188504e-02
65 21 1.1464117662043393e-02 -1.0401210709517453e-02 2.5342611338610443e+00 3.6136358508197755e-02
66 21 8.6831260305573858e-03 -8.7685621833870353e-03 2.4450434118304316e+00 3.5071187650686675e-02
67 21 5.5067154198047783e-03 -7.4699862274778556e-03 2.3575171918526414e+00 3.3147846949162604e-02
46 22 -7.0449306807385435e-05 6.9541254688860691e-03 3.8462003366201043e+00 3.7480880422250235e-03
47 22 -1.4376220495519640e-05 6.9200523633839942e-03 3.8348107954675510e+00 7.5041260935584716e-03
48 22 2.7467731222376320e-04 6.7724731026497127e-03 3.8159278699085903e+00 1.1263414453561838e-02
49 22 8.6526152263487915e-04 6.4095349642244275e-03 3.7897058367979266e+00 1.5000110719996081e-02
50 22 1.7801606831351967e-03 5.7433080798464323e-03 3.7563621818235422e+00 1.8666592640497342e-02
51 22 2.9963890622926675e-03 4.7262866291639784e-03 3.7161812699998515e+00 2.2191406305823023e-02
52 22 4.4520748244689405e-03 3.3577865823987457e-03 3.6695099683875614e+00 2.5499793288717244e-02
53 22 6.0571989537343291e-03 1.6715349130283119e-03 3.6167536073413378e+00 2.8505692325385454e-02
54 22 7.7063492969091296e-03 -2.8938859608522866e-04 3.5583685992744662e+00 3.1142032713363701e-02
55 22 9.2897868070741518e-03 -2.4856635860555807e-03 3.4948526553527666e+00 3.3358551532695180e-02
56 22 1.0703298481132606e-02 -4.8791154922520740e-03 3.4267361673688725e+00 3.5118161428701930e-02
57 22 1.1855035957849513e-02 -7.4061871989512303e-03 3.3545743254611660e+00 3.6405091527723719e-02
58 22 1.2668245450805752e-02 -9.9532055216555813e-03 3.2789424961948241e+00 3.7237555286431662e-02
59 22 1.3084362522347818e-02 -1.2342944030483997e-02 3.2004214945512284e+00 3.7608016859132669e-02
60 22 1.3064065150659214e-02 -1.4359152139198713e-02 3.1195958049523469e+00 3.7514558622903947e-02
61 22 1.2589532261629734e-02 -1.5794281985108176e-02 3.0370335746058879e+00 3.7012174217746746e-02
62 22 1.1663566021906671e-02 -1.6513702345218907e-02 2.9532764754743015e+00 3.6260686559867764e-02
63 22 1.0308118861170027e-02 -1.6502293938751245e-02 2.8688205550427193e+00 3.5457138907730140e-02
64 22 8.5588276467537371e-03 -1.5878726406335527e-02 2.7841277154443778e+00 3.4729868235104169e-02
65 22 6.4539802622594639e-03 -1.4858587651869384e-02 2.6996507669467382e+00 3.4059863896111771e-02
66 22 4.0182260293560633e-03 -1.3674148172850377e-02 2.6158720230363572e+00 3.3292980508267740e-02
67 22 1.2476762605800654e-03 -1.2473006564673176e-02 2.5333251112595070e+00 3.2199669156576960e-02
46 12 8.2320905105907529e-03 2.2115631212954099e-02 2.9618276172116600e+00 4.8940496226270967e-03
47 12 1.6611248876999340e-02 1.9311287936368087e-02 2.9412196895728004e+00 9.6273831018199151e-03
48 12 2.5175211267583236e-02 1.5077111140260870e-02 2.9073929263822129e+00 1.5369099858192346e-02
49 12 3.3938251754845945e-02 1.0154455094181274e-02 2.8598340477172868e+00 1.8985410213209816e-02
50 12 4.2688751176236238e-02 5.3645330078426617e-03 2.8003505875324293e+00 2.6669172098597139e-02
51 12 5.1166710743074981e-02 2.4497836484232739e-03 2.7275837662676432e+00 3.1286535376945750e-02
52 12 5.9179785389584329e-02 2.2600737048917023e-03 2.6425671354619249e+00 3.4354663176138334e-02
53 12 6.6216245835602483e-02 5.0878150647569315e-03 2.5470739094270782e+00 4.8196055895039641e-02
54 12 7.1992352340940716e-02 1.0694753764058340e-02 2.4395215691993757e+00 5.7399379430447435e-02
55 12 7.6755399465316052e-02 1.7056866034872806e-02 2.3208815564309115e+00 4.5515260591472692e-02
56 12 8.0519011579896937e-02 2.1186891451858605e-02 2.1976140284218211e+00 3.0329631453222549e-02
57 12 8.2810947249035191e-02 2.1170212309800499e-02 2.0766034271175573e+00 3.6270778751756355e-02
58 12 8.3437596316591311e-02 1.6848047448639079e-02 1.9608865234130002e+00 5.9464092692347849e-02
59 12 8.2597580650171698e-02 9.1341175992936691e-03 1.8500351286395105e+00 8.0416965463074738e-02
60 12 8.0846471998148262e-02 -9.4001955755015942e-04 1.7429903543846961e+00 8.7447730352884390e-02
61 12 7.8504528069929372e-02 -1.2552368634715970e-02 1.6395365250169194e+00 8.3590369138713594e-02
62 12 7.5533638864664618e-02 -2.4919624641105649e-02 1.5400842797679255e+00 7.7599028717174431e-02
63 12 7.1789181911941599e-02 -3.7140862617139205e-02 1.4448744859547602e+00 7.5400029713406438e-02
64 12 6.7193716175038540e-02 -4.8300057290690167e-02 1.3536967045228512e+00 7.6436534836526751e-02
65 12 6.1835225026861784e-02 -5.7702768429302935e-02 1.2661723862914072e+00 7.6876196923511081e-02
66 12 5.6015094515013186e-02 -6.5136071311716406e-02 1.1821040789335460e+00 7.4340494129820689e-02
67 12 5.0173263700077832e-02 -7.1032157398399465e-02 1.1015187217870031e+00 6.8787359901584980e-02
46 13 6.9562968658897174e-03 2.2503664470198945e-02 3.0445787863191440e+00 4.6532726780925430e-03
47 13 1.4072018643270517e-02 2.0241017860088230e-02 3.0249327629216634e+00 8.9626504304551515e-03
48 13 2.1446602821652051e-02 1.6535061602644823e-02 2.9929366679675566e+00 1.4042370505417644e-02
49 13 2.9057561800052079e-02 1.1916867575347781e-02 2.9482557504682223e+00 1.8608327503964107e-02
50 13 3.6824142467195141e-02 6.8486685798989488e-03 2.8916420008420638e+00 2.2751715019474920e-02
51 13 4.4462554036773155e-02 2.3123446469024739e-03 2.8238358854132937e+00 2.9514005325473502e-02
52 13 5.1739415860868394e-02 -3.3273747894992556e-04 2.7442245887252499e+00 3.2667680894422645e-02
53 13 5.8414033371157061e-02 -3.5961640413731990e-04 2.6541325254079995e+00 3.7024936036151458e-02
54 13 6.4055665866012787e-02 2.5222139135606873e-03 2.5543599813348186e+00 4.9500807909346571e-02
55 13 6.8493575205861745e-02 7.8336331868567831e-03 2.4439842554253750e+00 5.6618433100926388e-02
56 13 7.1945505860103176e-02 1.3723190065897081e-02 2.3245270178097868e+00 4.6866108975236298e-02
57 13 7.4453562111853361e-02 1.7717001023246227e-02 2.2013910184974743e+00 3.3344594666439076e-02
58 13 7.5702268480538334e-02 1.8094584157261083e-02 2.0804947407453485e+00 3.5243465283733517e-02
59 13 7.5531185297967707e-02 1.4483085181471032e-02 1.9650649487158229e+00 5.2890602160985657e-02
60 13 7.4026402586553630e-02 7.5277968228264118e-03 1.8552143839056927e+00 7.3291807074672088e-02
61 13 7.1651534114764368e-02 -1.8271082135919328e-03 1.7498907026129020e+00 8.4149513144255811e-02
62 13 6.8751192595554969e-02 -1.2697250959953025e-02 1.6484034925666458e+00 8.3104483895744874e-02
63 13 6.5396075805744663e-02 -2.4258163357222452e-02 1.5507780059059464e+00 7.5967882001677201e-02
64 13 6.1500549181132937e-02 -3.5670611263537849e-02 1.4573002184194368e+00 6.9761483830757726e-02
65 13 5.6925331070261750e-02 -4.6127838796670435e-02 1.3680746893704490e+00 6.7180223928964153e-02
66 13 5.1688481539725724e-02 -5.5058527599851408e-02 1.2829642207136853e+00 6.7142983017479424e-02
67 13 4.6075514091289835e-02 -6.2403473787500600e-02 1.2017557056891981e+00 6.7159687634448753e-02
46 14 5.7590251366942524e-03 2.1721073944672108e-02 3.1286096610568563e+00 4.2693196303457059e-03
47 14 1.1697254464383543e-02 1.9940220666416084e-02 3.1102325055097704e+00 8.7536177480758252e-03
48 14 1.7939832396988365e-02 1.7049672781349064e-02 3.0796945444523240e+00 1.2929942877697291e-02
49 14 2.4483662368946731e-02 1.3129604316414295e-02 3.0376231645743217e+00 1.7907921625605994e-02
50 14 3.1239406700376452e-02 8.5179559039992043e-03 2.9840003096148520e+00 2.1760859158622522e-02
51 14 3.8032143218986063e-02 3.6341965920997721e-03 2.9198035731818854e+00 2.6200771510346648e-02
53 14 5.0661309132451274e-02 -2.9274557377189617e-03 2.7606822480069755e+00 3.4021016413777964e-02
54 14 5.6049570141121191e-02 -2.8111244430837979e-03 2.6669503598276267e+00 3.8855104759650566e-02
55 14 6.0409907739999671e-02 1.7325019540784139e-05 2.5645263789419750e+00 4.9446393390087648e-02
56 14 6.3639667264546784e-02 4.9755521743176656e-03 2.4530574957789368e+00 5.5362956501374266e-02
57 14 6.5915261366348385e-02 1.0452153917156827e-02 2.3341515418095580e+00 4.8266298613478462e-02
58 14 6.7309157608385281e-02 1.4391117411401359e-02 2.2121959089620824e+00 3.6564207571319583e-02
59 14 6.7651905710379753e-02 1.5231851741165295e-02 2.0922402294823588e+00 3.4569152827017710e-02
60 14 6.6826119193148306e-02 1.2421610074258680e-02 1.9775863507597762e+00 4.5759963809158290e-02
61 14 6.4830549267190563e-02 6.3233602962785617e-03 1.8689451580711378e+00 6.3431147422894962e-02
62 14 6.1998524170224237e-02 -2.2481605139210081e-03 1.7655890898079178e+00 7.6902598361623609e-02
63 14 5.8614298032223372e-02 -1.2344783351282673e-02 1.6666012494767211e+00 8.0562903160310340e-02
64 14 5.4822127046988939e-02 -2.3024427166761410e-02 1.5715662660553544e+00 7.5988855777348457e-02
65 14 5.0624311835398152e-02 -3.3406972642086627e-02 1.4805379403332957e+00 6.8167731693335440e-02
66 14 4.5915826663911349e-02 -4.2773282423611017e-02 1.3936890620699671e+00 6.1378190512027579e-02
67 14 4.0735521166962142e-02 -5.0767907942862837e-02 1.3111005073382813e+00 5.7513348138022446e-02
46 15 4.6727088041120099e-03 2.0063260702217433e-02 3.2141907266992353e+00 4.0787645808751417e-03
47 15 9.5374165317105887e-03 1.8737923428240384e-02 3.1968188282504086e+00 8.3067387648968587e-03
48 15 1.4720036398783403e-02 1.6572294006950587e-02 3.1679532621703967e+00 1.2527339419658902e-02
49 15 2.0253545105211369e-02 1.3529173485721125e-02 3.1280381829985919e+00 1.6818517253924005e-02
50 15 2.6047034959698422e-02 9.6818122533588666e-03 3.0774332366132846e+00 2.1328469267764907e-02
51 15 3.1957105801288327e-02 5.2373360030571713e-03 3.0165389113340075e+00 2.4885518434941876e-02
52 15 3.7768248365844026e-02 6.5194055487508625e-04 2.9461909643403503e+00 2.9088252237913774e-02
53 15 4.3230340825622826e-02 -3.1762152363348237e-03 2.8667069770363969e+00 3.3063968302552822e-02
54 15 4.8161394805061992e-02 -5.2960057208420869e-03 2.7785295764949329e+00 3.5219150158049474e-02
55 15 5.2351879609290317e-02 -5.0811408195443799e-03 2.6825202806330819e+00 3.9794746623416054e-02
56 15 5.5557759391286321e-02 -2.3990362675141083e-03 2.5789493438000242e+00 4.8393091849310357e-02
57 15 5.7711322908972539e-02 2.1591656312026837e-03 2.4678397086719177e+00 5.3617159654531218e-02
58 15 5.8945769478622644e-02 7.2340677037824085e-03 2.3506584784069706e+00 4.9249860352064398e-02
59 15 5.9360374298848988e-02 1.1123477377651816e-02 2.2308766811921057e+00 3.9725066628139585e-02
60 15 5.8908949449781318e-02 1.2425412824427022e-02 2.1127097986248655e+00 3.4884809353343635e-02
61 15 5.7529751247830045e-02 1.0460710068973415e-02 1.9993774738603840e+00 3.9724115591299604e-02
62 15 5.5175252218634688e-02 5.3409711204844730e-03 1.8921308359354503e+00 5.2496712396929233e-02
63 15 5.2037410450241843e-02 -2.2747851642737934e-03 1.7907800253263921e+00 6.5762053150155264e-02
64 15 4.8279033811402944e-02 -1.1417834928251082e-02 1.6944982196290677e+00 7.3470040151639646e-02
65 15 4.4052468865163313e-02 -2.1031231645956900e-02 1.6025947320439060e+00 7.3704137425373142e-02
66 15 3.9426873580270957e-02 -3.0165440108044003e-02 1.5147700073386217e+00 6.8127974884097872e-02
67 15 3.4411629090671324e-02 -3.8177673850620604e-02 1.4309888709606662e+00 6.0169775697118955e-02
46 16 3.6833723122651186e-03 1.7999322118428033e-02 3.3011173281385342e+00 3.9481170514855486e-03
47 16 7.5627146100830612e-03 1.7047643559931484e-02 3.2846573235025076e+00 7.9218846321623630e-03
48 16 1.1772641824535333e-02 1.5444235372745510e-02 3.2574468827068142e+00 1.2110715364812945e-02
49 16 1.6354161193546012e-02 1.3167777762442129e-02 3.2196733627750476e+00 1.6188179059026857e-02
50 16 2.1246189621560493e-02 1.0152896374668940e-02 3.1718167193611371e+00 2.0438844117269744e-02
51 16 2.6304957685888194e-02 6.4394766376279049e-03 3.1142493966402136e+00 2.4439079384121383e-02
52 16 3.1359040062044562e-02 2.2103847266294707e-03 3.0475721801555138e+00 2.7792273190949679e-02
53 16 3.6197634224528992e-02 -2.0507635615149948e-03 2.9725001173349979e+00 3.1423980271713794e-02
54 16 4.0616289533776703e-02 -5.5389542805622414e-03 2.8894886955443386e+00 3.4343892798436602e-02
55 16 4.4461194946433198e-02 -7.4341105775384249e-03 2.7991299210096443e+00 3.6175689715075537e-02
56 16 4.7560655373134329e-02 -7.1993137880962807e-03 2.7021113813156039e+00 4.0004949285408660e-02
57 16 4.9737790163413516e-02 -4.7677302662924052e-03 2.5987183510924083e+00 4.6662917920987514e-02
58 16 5.0942647666601434e-02 -6.7611998961016192e-04 2.4891856555396528e+00 5.1322770918066474e-02
59 16 5.1273090967404962e-02 3.9605740158815596e-03 2.3747556034614536e+00 4.9362516296532315e-02
60 16 5.0846257578654463e-02 7.7494388222478826e-03 2.2580959622295702e+00 4.2331594612434693e-02
61 16 4.9705535518246448e-02 9.4522667959986637e-03 2.1426194557804705e+00 3.6243178822971296e-02
62 16 4.7846661358890936e-02 8.3311862515080114e-03 2.0312922204942891e+00 3.5988962507601474e-02
63 16 4.5211639124851426e-02 4.3109393023718686e-03 1.9257436684324223e+00 4.2810552872153643e-02
64 16 4.1869554240592022e-02 -2.1050072336794476e-03 1.8263686174480975e+00 5.2865507697845593e-02
65 16 3.7850343053435286e-02 -9.9817971770572757e-03 1.7326940379685423e+00 6.1696903443622622e-02
66 16 3.3261766316768859e-02 -1.8225412174832832e-02 1.6440426911644010e+00 6.5942704012431755e-02
67 16 2.8200411974401714e-02 -2.5872170714281471e-02 1.5598539266695661e+00 6.4722442427902122e-02
46 17 2.7909814229549758e-03 1.5920183606843382e-02 3.3891686321027614e+00 3.8217613950534634e-03
47 17 5.7741265423955461e-03 1.5230325973430542e-02 3.3736568026366642e+00 7.7020360122805644e-03
48 17 9.0900545589784575e-03 1.4047303912937289e-02 3.3479834585657664e+00 1.1679394866404845e-02
49 17 1.2787930782771744e-02 1.2333212846848471e-02 3.3123673885727012e+00 1.5749777690086165e-02
50 17 1.6826932935259425e-02 1.0021048269789475e-02 3.2671453997551376e+00 1.9714571173986332e-02
51 17 2.1085570430381777e-02 7.0537296317284915e-03 3.2127748470469406e+00 2.3703568521888527e-02
52 17 2.5400563235211501e-02 3.4689901226021358e-03 3.1497236179210866e+00 2.7244588055865368e-02
53 17 2.9599708613581251e-02 -5.2985945916628413e-04 3.0786472900072428e+00 3.0309653255466838e-02
54 17 3.3498757437941375e-02 -4.4679986315416869e-03 3.0002194192096585e+00 3.3273885583864356e-02
55 17 3.6934802065971918e-02 -7.6466658828618153e-03 2.9150116141250999e+00 3.5405738363668525e-02
56 17 3.9780261323639550e-02 -9.3765356275258716e-03 2.8236630049889988e+00 3.6848053322292740e-02
57 17 4.1900445448949483e-02 -9.2174248612029979e-03 2.7267771538976673e+00 3.9699731410389877e-02
58 17 4.3170516650518048e-02 -7.1346125645286819e-03 2.6246910088478703e+00 4.4531992937905808e-02
59 17 4.3553651595013704e-02 -3.5773965530214399e-03 2.5177510847660365e+00 4.8500992058605565e-02
60 17 4.3124168327343518e-02 5.6368287251822773e-04 2.4069631138699674e+00 4.8310456949154437e-02
61 17 4.2003613809055616e-02 4.1622615545271130e-03 2.2943196886427137e+00 4.3798874136638445e-02
62 17 4.0285594004808432e-02 6.1489764561703901e-03 2.1824801675449335e+00 3.8044248276059706e-02
63 17 3.8008328976067290e-02 5.8030312107470658e-03 2.0740145070547964e+00 3.4732580319063101e-02
64 17 3.5122279050693012e-02 2.9473012505933211e-03 1.9707073577339782e+00 3.6206107264528851e-02
65 17 3.1611449215169424e-02 -2.0307488512853163e-03 1.8734218173768611e+00 4.1351502987761288e-02
66 17 2.7409081440758112e-02 -8.2808760527334647e-03 1.7821573734704503e+00 4.7975601582673208e-02
67 17 2.2566614702527379e-02 -1.4777251246354432e-02 1.6964961362780890e+00 5.3116761485928872e-02
46 18 1.9888451966816999e-03 1.4021965216939283e-02 3.4782737798598640e+00 3.7480446480427179e-03
47 18 4.1623402545757845e-03 1.3521582138279177e-02 3.4636779370366542e+00 7.5587735960865243e-03
48 18 6.6597497657014974e-03 1.2643079848070277e-02 3.4394870635857835e+00 1.1423635090215958e-02
49 18 9.5416610163460789e-03 1.1330183402671305e-02 3.4059343099467463e+00 1.5367357019324781e-02
50 18 1.2781785756659978e-02 9.5274516078279695e-03 3.3633039568756593e+00 1.9263629092100620e-02
51 18 1.6283324246881878e-02 7.1728715697225286e-03 3.3120003602160755e+00 2.3024108279582369e-02
52 18 1.9900071101208141e-02 4.2372186857669086e-03 3.2524935301396409e+00 2.6615976372997095e-02
53 18 2.3471883502174544e-02 7.8028090550609562e-04 3.1853218633770704e+00 2.9717802199741763e-02
54 18 2.6842006787867002e-02 -2.9790907710546396e-03 3.1111436216572383e+00 3.2390976982969548e-02
55 18 2.9857347644952219e-02 -6.6080404335774516e-03 3.0306271927543826e+00 3.4719388992462207e-02
56 18 3.2388776246008645e-02 -9.5204414056351168e-03 2.9444062640073065e+00 3.6248830083227955e-02
57 18 3.4332464060743161e-02 -1.1153834917633521e-02 2.8531323206690047e+00 3.7256726283129503e-02
58 18 3.5588281157605997e-02 -1.1151980540540913e-02 2.7573785448446975e+00 3.9099157827241708e-02
59 18 3.6073139969224670e-02 -9.4878637924174277e-03 2.6575414348954367e+00 4.2274255123182496e-02
60 18 3.5765297231992732e-02 -6.5170914058027551e-03 2.5540235057487002e+00 4.5336432789823591e-02
61 18 3.4725521711943735e-02 -2.9374493288927038e-03 2.4476265505146331e+00 4.6107117117330045e-02
62 18 3.3066637448603477e-02 3.4833225477064243e-04 2.3398034757533850e+00 4.3736967218314861e-02
63 18 3.0894860886939438e-02 2.4511253415925318e-03 2.2325417533228782e+00 3.9338116741805630e-02
64 18 2.8264886075118477e-02 2.7357077701325432e-03 2.1279344884093878e+00 3.5084628430534982e-02
65 18 2.5136288846852269e-02 1.0206940192492530e-03 2.0276940433449395e+00 3.3068294163427249e-02
66 18 2.1449081800845794e-02 -2.3717702492781385e-03 1.9329412963178945e+00 3.3592561378594121e-02
67 18 1.7096619147710754e-02 -6.7032214349202167e-03 1.8440874688983158e+00 3.6202871094686381e-02
46 19 1.2740052234055854e-03 1.2350210657775395e-02 3.5684060203121968e+00 3.7201645059424799e-03
47 19 2.7212201875440236e-03 1.2001927149062589e-02 3.5546707140375728e+00 7.4791346619291245e-03
48 19 4.4764390101243081e-03 1.1355911254520032e-02 3.5319078360177771e+00 1.1295045927064373e-02
49 19 6.6075072696647466e-03 1.0342908700083949e-02 3.5003174194241269e+00 1.5130435072169672e-02
50 19 9.1052165937187540e-03 8.9045236322818043e-03 3.4601781732067960e+00 1.8946448272953505e-02
51 19 1.1893067239594716e-02 6.9977629143776459e-03 3.4118409297051429e+00 2.2605247225466280e-02
52 19 1.4848188684836380e-02 4.5921974363031135e-03 3.3557460379695643e+00 2.6048117934727718e-02
53 19 1.7823792081225014e-02 1.6919894206269155e-03 3.2923930029914326e+00 2.9184039025783915e-02
54 19 2.0674535497862880e-02 -1.6210490317361559e-03 3.2223522479971911e+00 3.1834605193882336e-02
55 19 2.3264432885013630e-02 -5.1340455175893033e-03 3.1462720165325053e+00 3.4054836447399359e-02
56 19 2.5468973659078169e-02 -8.4746311582271777e-03 3.0648138661854425e+00 3.5814690807619433e-02
57 19 2.7185780248629294e-02 -1.1166453513251996e-02 2.9786335347801409e+00 3.6860472139579437e-02
58 19 2.8333723612586632e-02 -1.2759505521837479e-02 2.8883780574919058e+00 3.7438130639472468e-02
59 19 2.8843827820327787e-02 -1.2964934416846794e-02 2.7946172053878833e+00 3.8373685408250320e-02
60 19 2.8667977155309006e-02 -1.1755985697228317e-02 2.6977996871399501e+00 4.0130296706124377e-02
61 19 2.7801788452603358e-02 -9.4045764822074229e-03 2.5983584395932584e+00 4.2117291037893925e-02
62 19 2.6299599400936718e-02 -6.4555749924357720e-03 2.4969451228278139e+00 4.3078308912578182e-02
63 19 2.4256020931767673e-02 -3.6172152135026726e-03 2.3946060650857777e+00 4.2113802671415852e-02
64 19 2.1762175416170232e-02 -1.5923922742227502e-03 2.2927765336266543e+00 3.9302558317053801e-02
65 19 1.8862549413262562e-02 -8.7074335629146529e-04 2.1930576312705052e+00 3.5553823105421670e-02
66 19 1.5516932140723605e-02 -1.5648050575657912e-03 2.0969270417763166e+00 3.2162999347674567e-02
67 19 1.1652554810847992e-02 -3.3693120869891261e-03 2.0055284054058959e+00 2.9744460882670277e-02
46 20 6.4219185273366251e-04 1.0876337345892564e-02 3.6595351914393377e+00 3.7167532655139695e-03
47 20 1.4435391412424611e-03 1.0656389877619160e-02 3.6466207366037633e+00 7.4595900663065153e-03
48 20 2.5320298354714480e-03 1.0205691506156566e-02 3.6252167880495723e+00 1.1238847306097664e-02
49 20 3.9791046154489494e-03 9.4374895997675935e-03 3.5955026103502963e+00 1.5024415383073990e-02
50 20 5.7908163792241753e-03 8.2833098807725929e-03 3.5577351981450649e+00 1.8758139057437350e-02
51 20 7.9115198759729891e-03 6.7069717339340437e-03 3.5122426907579301e+00 2.2359973283709585e-02
52 20 1.0240253604894903e-02 4.6977386498878058e-03 3.4594238125945131e+00 2.5714324397811638e-02
53 20 1.2649573038868015e-02 2.2597020500908561e-03 3.3997480349232916e+00 2.8766435703192518e-02
54 20 1.5004341089279456e-02 -5.7638147831177793e-04 3.3337364017495315e+00 3.1428584395995024e-02
55 20 1.7177300365405462e-02 -3.7204760349359776e-03 3.2619693079776049e+00 3.3615208883122326e-02
56 20 1.9053427418839912e-02 -6.9827970390013887e-03 3.1850758566208643e+00 3.5361925905582889e-02
57 20 2.0532355348241549e-02 -1.0056693976491310e-02 3.1037019662754166e+00 3.6613755841021015e-02
58 20 2.1534336687860093e-02 -1.2564944066849571e-02 3.0184961890461777e+00 3.7252524175207462e-02
59 20 2.1999846575507822e-02 -1.4150430307438301e-02 2.9300904208056120e+00 3.7434173644289741e-02
60 20 2.1887481486382473e-02 -1.4583138966977816e-02 2.8390565602517466e+00 3.7651233442616887e-02
61 20 2.1178138222504889e-02 -1.3835787501924825e-02 2.7458784717581595e+00 3.8279927251220626e-02
62 20 1.9885015851241826e-02 -1.2119293594843955e-02 2.6510115491010788e+00 3.9198543312533904e-02
63 20 1.8059331402610974e-02 -9.8536576367896766e-03 2.5550063150746274e+00 3.9793371217983362e-02
64 20 1.5773099571040155e-02 -7.5784453304910569e-03 2.4586334496939721e+00 3.9424449256578641e-02
65 20 1.3087860481343286e-02 -5.8041683380735225e-03 2.3629056374470148e+00 3.7786209102427817e-02
66 20 1.0020520050994554e-02 -4.8469535088859839e-03 2.2689919292724641e+00 3.5039084568036095e-02
67 20 6.5244445856917233e-03 -4.7093223782647461e-03 2.1780502371148662e+00 3.1710259015561716e-02
46 21 8.9128368737065300e-05 9.5570488742428190e-03 3.7516291105765736e+00 3.7257619797768067e-03
47 21 3.2219923029953358e-04 9.4457099244076789e-03 3.7395007334865729e+00 7.4685081146245022e-03
48 21 8.1819520178354590e-04 9.1648264385956035e-03 3.7193938578353354e+00 1.1227248931542871e-02
49 21 1.6497726721416183e-03 8.6115743728392841e-03 3.6914737629722842e+00 1.4979513836412285e-02
50 21 2.8345958407722492e-03 7.7027647421426797e-03 3.6559732375348060e+00 1.8666417597524628e-02
51 21 4.3368453272751625e-03 6.3964939402161866e-03 3.6131975305027124e+00 2.2216371405894601e-02
52 21 6.0772946941374016e-03 4.6919520259997268e-03 3.5635161566982889e+00 2.5538702026676036e-02
53 21 7.9486831226330788e-03 2.6110003888382047e-03 3.5073633401287641e+00 2.8542540509049204e-02
54 21 9.8307663723135735e-03 1.8284621909457906e-04 3.4452273712904700e+00 3.1177192876390637e-02
55 21 1.1603812516479196e-02 -2.5482712643570423e-03 3.3776408027364919e+00 3.3374189417081861e-02
56 21 1.3158536955116788e-02 -5.4980461869122412e-03 3.3051782429945202e+00 3.5104214576641188e-02
57 21 1.4399148456529537e-02 -8.5067868395944744e-03 3.2284450298191016e+00 3.6380559537973318e-02
58 21 1.5246283131814678e-02 -1.1332078778371646e-02 3.1480620746271688e+00 3.7176406611832892e-02
59 21 1.5640381619025027e-02 -1.3678291392531660e-02 3.0646513847180059e+00 3.7439681801356012e-02
60 21 1.5542391760995436e-02 -1.5268768474773606e-02 2.9788221916736410e+00 3.7271910486293518e-02
61 21 1.4934620427490896e-02 -1.5922956557893206e-02 2.8911362022988358e+00 3.6949005281380773e-02
62 21 1.3820918377492225e-02 -1.5622035671203224e-02 2.8020973065078456e+00 3.6757488054672861e-02
63 21 1.2229395075564531e-02 -1.4530053832910334e-02 2.7121684564479662e+00 3.6763923653264842e-02
64 21 1.0207224119640888e-02 -1.2965930748153904e-02 2.6218450922859118e+00 3.6749409009825422e-02
65 21 7.8041552100696276e-03 -1.1315267095563424e-02 2.5317193536464035e+00 3.6356009991912172e-02
66 21 5.0482814913731409e-03 -9.9051399780963421e-03 2.4425179018296177e+00 3.5256765320179198e-02
67 21 1.9269928049393099e-03 -8.8774901654848047e-03 2.3550665542561169e+00 3.3300182057361016e-02
46 22 -3.8994471258567323e-04 8.3684304075300388e-03 3.8446432825394647e+00 3.7383891669291952e-03
47 22 -6.5137492010006171e-04 8.3452914956516459e-03 3.8332674463125826e+00 7.4841498287616243e-03
48 22 -6.7543219769506324e-04 8.2076779478259063e-03 3.8144040079702095e+00 1.1232382226180804e-02
49 22 -3.9059190241916140e-04 7.8442696630428785e-03 3.7882027491863011e+00 1.4957449596081824e-02
50 22 2.2943990907027355e-04 7.1579555953033055e-03 3.7548762320812208e+00 1.8612597087384986e-02
51 22 1.1654674089544472e-03 6.0944231086119552e-03 3.7147038968034982e+00 2.2127345901466245e-02
52 22 2.3592032909911798e-03 4.6488088358172582e-03 3.6680287372035867e+00 2.5428504144946542e-02
53 22 3.7236454887383734e-03 2.8531815032384880e-03 3.6152531520115416e+00 2.8430302247544319e-02
54 22 5.1554710996441020e-03 7.5092763876121870e-04 3.5568325241922323e+00 3.1067405569729593e-02
55 22 6.5460135179683668e-03 -1.6156769481794420e-03 3.4932646290774954e+00 3.3289199314153105e-02
56 22 7.7911948008459039e-03 -4.2022265959678279e-03 3.4250819678858231e+00 3.5057777470142375e-02
57 22 8.7984655144421418e-03 -6.9353373024504282e-03 3.3528432475094982e+00 3.6358316994752511e-02
58 22 9.4897326873542194e-03 -9.6890856226222958e-03 3.2771285566929396e+00 3.7207169219469698e-02
59 22 9.8047141185438891e-03 -1.2274391132122493e-02 3.1985241518588774e+00 3.7594401909511861e-02
60 22 9.7022846197048693e-03 -1.4466407414033659e-02 3.1176198068181926e+00 3.7517387689909830e-02
61 22 9.1628460346133735e-03 -1.6054481502297709e-02 3.0349881016829281e+00 3.7038340921861382e-02
62 22 8.1877960101374905e-03 -1.6906268943916478e-02 2.9511730690866949e+00 3.6322161552605120e-02
63 22 6.7985704523466986e-03 -1.7013652070128542e-02 2.8666719542446693e+00 3.5564883173022366e-02
64 22 5.0318597793385560e-03 -1.6505745491578919e-02 2.7819482015732526e+00 3.4885515016550378e-02
65 22 2.9288517454410610e-03 -1.5611525784394462e-02 2.6974584203556446e+00 3.4253712864638429e-02
66 22 5.1837565883542953e-04 -1.4578470450599831e-02 2.6136913274182998e+00 3.3510768886344966e-02
67 22 -2.1995243297600587e-03 -1.3568724209871780e-02 2.5311888574762533e+00 3.2427876220910257e-02
