Cg/asm doesn't scale
Nguyen, Hung V ERDC-ITL-MS Hung.V.Nguyen at usace.army.mil
Thu Apr 23 14:13:17 CDT 2009
Hello Matt,
>ILU is incredibly unpredictable.
I got the same result when running without setting ILU in sub_pc_type. It
seems to me that direct solver is set up as default when solving for
sub_ksp_type(?). Please let me know if it is not correct.
>You have not provided the Jacobi numbers, but the particular nonzero pattern
of the non-overlapping matrix must be
>much more amenable. Also, this is a really really bad preconditioner for
your system.
Indeed, the asm preconditioner is not really bad preconditioner for some of
my ill-conditioned systems. In some other SPD linear systems, I have found
that cg with asm preconditioner converges better than others. And, it does
scale well within the size of matrix, see attached file. However, it doesn't
scale in this case. Here is the solver time for cg/jacobi. The performance of
cg/asm is better than cg/jacobi in the range from 1 to 4 processors.
	Number Pes   Solver Time (secs)   #it      Solver Time(secs)
                     cg/asm                          cg/jacobi
	1                31.317345       544         1999.276566
	2               263.172225       6959        1188.067975
	4             734.828840        23233         984.062940
	8             805.217591        41250         538.102407
	16            611.813716        49262         308.547316
	32            345.331928        49792         170.074248
	64            212.084555        53771          92.398144
>I would put my time into figuring out why my system is so ill-conditioned
and try to formulate a good preconditioner, like an approximate system, etc.
The linear system is from groundwater flow in a water repellent soil that can
cause a very ill-conditioned linear system.
-Hung
-----Original Message-----
[mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Matthew Knepley
Sent: Thursday, April 23, 2009 11:12 AM
To: PETSc users list
Subject: Re: Cg/asm doesn't scale
On Thu, Apr 23, 2009 at 11:07 AM, Nguyen, Hung V ERDC-ITL-MS
<Hung.V.Nguyen at usace.army.mil> wrote:
	Hello,
	I tried to solver the SPD linear system with using cg/asm
preconditioner and
	found that it doesn't scale well, see table below. Note: it does
scale well
	with cg/jacobi preconditioner.
	Do you know why it doesn't scale?
ILU is incredibly unpredictable. You have not provided the Jacobi numbers,
but the particular nonzero pattern of the non-overlapping matrix must be much
more amenable. Also, this is a really really bad preconditioner for your
system. I would put my time into figuring out why my system is so
ill-conditioned and try to formulate a good preconditioner, like an
  Matt
	-hung
	1                31.317345         544
	2               263.172225        6959
	4             734.828840        23233
	8             805.217591        41250
	16            611.813716        49262
	32            345.331928        49792
	64            212.084555        53771
	1 :  aprun -n 1  ./test_matrix_read  -ksp_type cg -pc_type asm
-pc_asm_type
	basic   -sub_pc_type ilu -sub_ksp_type preonly -ksp_rtol 1.0e-12
-ksp_max_it
	100000
	Time in PETSc solver: 31.317345 seconds
	The number of iteration       = 544
	The solution residual error = 1.658653e-08
	2 norm 7.885361e-07
	 infinity norm 6.738382e-09
	 1 norm 2.124207e-04
	Application 679466 resources: utime 0, stime 0
	************************ Beginning new run ************************
	2 :  aprun -n 2  ./test_matrix_read  -ksp_type cg -pc_type asm
-pc_asm_type
-ksp_max_it
	100000
	Time in PETSc solver: 263.172225 seconds
	The number of iteration       = 6959
	The solution residual error = 1.794494e-08
	2 norm 6.579571e-07
	 infinity norm 8.745052e-09
	 1 norm 1.907733e-04
	-- Here is info about matrix A:
	Computed <structure:nrows> as <178353>
	Computed <structure:symmetry> as <0>
	Computed <structure:nnzeros> as <3578321>
	Computed <structure:max-nnzeros-per-row> as <27>
	Computed <structure:min-nnzeros-per-row> as <6>
	Computed <structure:left-bandwidth> as <76553>
	Computed <structure:right-bandwidth> as <76553>
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
Type: image/png
Desc: fig-B.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090423/29a21503/attachment.png>
