DeprecationWarning in ./config/configure.py
Hiroshi Katsurayama katsura at yamaguchi-u.ac.jp
Thu Apr 9 19:57:57 CDT 2009
Dear Satish
> Yes - you can saftely ignore these 'DeprecationWarning:' messages. It
> means : "the functionality works now - but it won't with newer
> versions".
Thank you very much for the detailed information about Python status.
I was relieved to hear the cause of the warnings.
Sincerely,
Hiroshi Katsurayama
On Thu, 9 Apr 2009 09:45:13 -0500 (CDT)
Satish Balay <balay at mcs.anl.gov> wrote:
> > Are these warnings ignorable?
> versions".
> Python changed considerably between python-2 and the new
> python-3. Python-2.6 is supporsed to be a bridge that enables easier
> transition to python-3.
> We need to eventually get configure working with both python3 and python2
> Satish
> On Thu, 9 Apr 2009, Hiroshi Katsurayama wrote:
> > Hello,
> > I try to use PETSC-3.0.0-p4 on Ubuntu 9.04 linux (present beta version)
> > whose python version is 2.6.1.
> > When ./config/configure.py, the following there "DeprecationWarning"s appear before "TESTING:".
> >              Configuring PETSc to compile on your system
> > /home/hiroshi/local/petsc/petsc-3.0.0-p4/config/BuildSystem/config/compilers.py:7: DeprecationWarning: the sets module is deprecated
> >   import sets
> > /home/hiroshi/local/petsc/petsc-3.0.0-p4/config/PETSc/package.py:7: DeprecationWarning: the md5 module is deprecated; use hashlib instead
> >   import md5
> > /home/hiroshi/local/petsc/petsc-3.0.0-p4/config/BuildSystem/script.py:101: DeprecationWarning: The popen2 module is deprecated.  Use the subprocess module.
> >   import popen2
> > TESTING:
> > The configure process after TESTING seems to finish successfully,
> > and next "make all" and "make test" also seem to finish normally.
> > I attache the detailed log file of my configure (my_linux_gnu_intel.log).
> > But these warnings also appear in
> > simply
> > "./config/configure.py"
> > irrespective of compiler or blas.
> > When I tried the configure on Ubuntu 8.10 whose python version is 2.5.2,
> > these warning did not appear.
> > Hence the latest python (version 2.6.1) on Ubuntu 9.04 BETA maybe cause these warnings.
> > Thank you.
> > Sincerely,
> > Hiroshi Katsurayama
葛山 浩
山口大学 大学院理工学研究科 システム設計工学系
機械エネルギー工学分野 応用熱工学研究室 助教
TEL   : 0836-85-9108
FAX   : 0836-85-9101
E-mail: katsura at yamaguchi-u.ac.jp
〒755-8611 山口県宇部市常盤台2-16-1
山口大学 工学部 機械工学科
