petsc error
Tabrez Ali stali at purdue.edu
Fri Oct 31 15:42:46 CDT 2008
Hello
The attached trivial program work fines on my old setup (petsc-2.3.3-p7
built with old Intel compilers and MPICH1) but fails with the
petsc-2.3.3-p15 which I just compiled on my new machine.
Any ideas as to what is wrong?
Thanks in advance.
T
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081031/5dfddd39/attachment.bin>
Type: text/x-makefile
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081031/5dfddd39/attachment-0001.bin>
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Read from file failed!
[0]PETSC ERROR: Read past end of file!
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Petsc Release Version 2.3.3, Patch 15, Tue Sep 23 10:02:49 CDT 2008 HG revision: 31306062cd1a6f6a2496fccb4878f485c9b91760
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: ./a.out on a linux-gnu named x61 by stali Fri Oct 31 16:20:47 2008
[0]PETSC ERROR: Libraries linked from /opt/petsc-2.3.3-p15/lib/linux-gnu-c-debug
[0]PETSC ERROR: Configure run at Fri Oct 31 14:12:26 2008
[0]PETSC ERROR: Configure options --with-mpi-dir=/opt/mpich2-intel --with-blas-lapack-dir=/opt/intel/mkl/10.0.5.025 --with-shared=yes --with-blacs=1 --download-blacs=ifneeded --with-scalapack=1 --download-scalapack=ifneeded --with-mumps=1 --download-mumps=ifneeded --with-parmetis=1 --download-parmetis=ifneeded
[0]PETSC ERROR: PetscBinaryRead() line 194 in src/sys/fileio/sysio.c
[0]PETSC ERROR: MatLoad_MPIAIJ() line 2540 in src/mat/impls/aij/mpi/mpiaij.c
[0]PETSC ERROR: MatLoad() line 131 in src/mat/utils/matio.c
[0]PETSC ERROR: VecLoad_Binary() line 263 in src/vec/vec/utils/vecio.c
[0]PETSC ERROR: VecLoad() line 130 in src/vec/vec/utils/vecio.c
[0]PETSC ERROR: Invalid argument!
[0]PETSC ERROR: Wrong type of object: Parameter # 1!
[0]PETSC ERROR: VecDuplicate() line 482 in src/vec/vec/interface/vector.c
[0]PETSC ERROR: Wrong type of object: Parameter # 2!
[0]PETSC ERROR: KSPSolve() line 307 in src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: VecView() line 719 in src/vec/vec/interface/vector.c
 Number of iterations =           0
[0]PETSC ERROR: Null argument, when expecting valid pointer!
[0]PETSC ERROR: Null Object: Parameter # 1!
[0]PETSC ERROR: MatDestroy() line 706 in src/mat/interface/matrix.c
[0]PETSC ERROR: VecDestroy() line 509 in src/vec/vec/interface/vector.c
