Matrix free preconditioning
Tim Kroeger tim.kroeger at cevis.uni-bremen.de
Wed Oct 15 01:49:28 CDT 2008
Dear Jed and Matt and all,
On Tue, 14 Oct 2008, Jed Brown wrote:
> I assume your matrix comes from the rank-1 update you brought up
> recently on the libmesh list?  That is
>  B = A + u v'
> for where A is an explicit matrix and u,v are vectors.
Yes, that's it.  Actually, I didn't know that anyone was reading both
libmesh-users and petsc-users.
> Did you try the
> rank-1 update I suggested?  In detail, let A^ be an approximate inverse
> of A (i.e. an application of any standard preconditioner) and form a
> preconditioner for B as
>  B^ = A^ - alpha w v' A^
> where
>  w = A^ u
>  alpha = 1/(1 + v' w).
Thank you very much for that suggestion.  I guess this would be the
best thing to do, but actually I have to admit that I am rather shy of
implemeting that, in particular with a sensible interface to libMesh.
Hence, I am thinking whether there might be some easier (altough
certainly less efficient) possibility.  I am thinking abouth the
following two ideas:
1. I could do MatShellSetOperation(A,MATOP_GET_DIAGONAL,...), which is
easy in my case and should enable PETSc to do at least JACOBI
preconditioning for that matrix, shouldn't it?
2. Following Matt's suggestion, I could handle an auxilary matrix C
for preconditioning.  In my case, it would choose C(i,j)=A(i,j)
whenever B(i,j)!=0, but C(i,j)=0 else.  I.e., C has the same sparsity
pattern as the (sparse) matrix B.  This would also be easy to
construct in my case.
Any opinion on this is welcome.
Best Regards,
Tim
Dr. Tim Kroeger                                        Phone +49-421-218-7710
tim.kroeger at mevis.de, tim.kroeger at cevis.uni-bremen.de  Fax   +49-421-218-4236
MeVis Research GmbH, Universitaetsallee 29, 28359 Bremen, Germany
Amtsgericht Bremen HRB 16222
Geschaeftsfuehrer: Prof. Dr. H.-O. Peitgen
