Performance Issues on ccNuma-System
Christoph Statz christoph.statz at ifn.et.tu-dresden.de
Mon Oct 13 12:56:51 CDT 2008
Hello Matt,
> That stuff is rarely worth running. Without a decent model of the
> performance, the
> data is no help. I am not talking about network bandwidth, but
> memory bandwidth.
> For a sparse matvec that comes from a simple scalar PDE, you need
> incredible
> amounts of bandwidth to drive the tiny amount of flops. The equation
> is in the paper.
>> Please see the paper
>>   by Kaushik and Gropp which models sparse matvec performance (on
>> Dinesh's website).
>> Which Paper on which website. Please send a link.
> I believe you want 11 and 17 here http://www.mcs.anl.gov/~kaushik/
> under the Publications link.
Got it. I will look at it and check the memory bandwidth
>> 3) You would see better performance using a block method. Sparse
>> matvec
>> without
>>   blocks will never see good percentages of peak (ditto for
>> backsolve).
>> How do I use the block methods?
>> Since I rely on the "user-level" interfaces kspsolve etcpp., I
>> don't see how
>> i could influence this.
> You can't unless your system has block structure. If it does, you can
> use the BAIJ
> matrix types.
I'll try it.
Thank you for your advice that far.
Sincerly,
Christoph
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081013/682f93d7/attachment.htm>
Desc: This is a digitally signed message part
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081013/682f93d7/attachment.pgp>
