Performance Issues on ccNuma-System
Christoph Statz christoph.statz at ifn.et.tu-dresden.de
Mon Oct 13 10:08:10 CDT 2008
Hello Matt and PETSc-users,
> 1) With any performance question, please send the output of -
> log_summary
You'll find the output attached
(But there is _really_ not much to see).
> 2) I think it is unlikely that cache misses are responsible for this
> performance. It is
>    much more likely that bandwidth limitations are responsible.
As far as I can see, there are neither bandwidth limitations nor
latency problems (since there is an infiniband-interconnect).
MPI-Performance (Vampirtrace + Scalasca) looks good (late senders/
receivers, barriers etcpp.).
PAPI-Instrumentation says: cache misses.
> Please see the paper
>    by Kaushik and Gropp which models sparse matvec performance (on
> Dinesh's website).
Which Paper on which website. Please send a link.
> 3) You would see better performance using a block method. Sparse
> matvec without
>    blocks will never see good percentages of peak (ditto for
> backsolve).
How do I use the block methods?
Since I rely on the "user-level" interfaces kspsolve etcpp., I don't
see how i could influence this.
You'll find basic source code attached.
Sincerly,
	Christoph
Christoph Statz
Institut für Nachrichtentechnik
Technische Universität Dresden
01062 Dresden
Email:  christoph.statz at mailbox.tu-dresden.de
Phone: +49 351 463 32287
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081013/740368c9/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081013/740368c9/attachment.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081013/740368c9/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081013/740368c9/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081013/740368c9/attachment-0002.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081013/740368c9/attachment-0002.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081013/740368c9/attachment-0003.htm>
Desc: This is a digitally signed message part
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081013/740368c9/attachment.pgp>
