analyze preconditioned operator?
Matt Funk mafunk at nmsu.edu
Thu Oct 9 15:38:00 CDT 2008
Hi Jed,
what you suggest seems like it might be even more efficient for sparse
matrices (which i am using) then using the KSPComputeExplicitOperator()
routine.
However, what kind of call do i make to apply the preconditioner to the
matrix. I have not really ever written a MatShell but it seems like there
should still be some PetscFunction that allows me to apply the
preconditioner.
Or am i misunderstanding you ... ?
matt
ps: also, did you mean to write B=PA where A is my original preconditioner?
On Thursday 09 October 2008, Jed Brown wrote:
> On Thu, Oct 9, 2008 at 20:22, Matt Funk <mafunk at nmsu.edu> wrote:
> > i am using PETSC and on top of it also SLEPC to do some matrix analysis.
> > In Slepc i simply pass it the Petsc matrix to analyze it.
> > However, is there anyway to analyze the preconditioned matrix at all?
> You can certainly write a MatShell which applies B = P^-1 A and hand
> this to SLEPc with no preconditioner.  This seems like a common thing
> so maybe SLEPc has an option to use the preconditioned operator.
> Jed
