question
Thu Oct 9 15:27:25 CDT 2008
On Thu, Oct 9, 2008 at 3:21 PM, Nguyen, Hung V ERDC-ITL-MS
<Hung.V.Nguyen at usace.army.mil> wrote:
> I am having trouble to use  MatCreateMPIAIWithArrays(). Do you have any
> example of using this function?
I would recommend writing a code that uses MatSetValues first, which you can
use to check your calls to MatCreateMPIAIJWithArrays(). What error are
you getting?
  Matt
> Thanks
> -----Original Message-----
> From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov] On
> Behalf Of Barry Smith
> Sent: Thursday, October 09, 2008 9:24 AM
> To: petsc-users at mcs.anl.gov
> Subject: Re: question
>   You can use the utilities: MatCreateSeqAIJWithArrays() or
> MatCreateMPIAIWithArrays() they
> handle all the details for you.
>    Barry
> On Oct 9, 2008, at 9:04 AM, Nguyen, Hung V ERDC-ITL-MS wrote:
>> All,
>> I am looking for an example code that read A (in csr format) and b.
>> Then it
>> builds A and b petsc format and solves Ax = b.
>> I found an example below, but it seems that it doesn't work.
>> If you have similar like an example below or let me know where is a
>> problem, I would appreciate very much.
>> Thanks,
>> -Hung
>>        Purpose: Test a sparse matrix solver.
>> #include <stdio.h>
>> #include "petscksp.h"
>> int main(int argc,char **args)
>>        /* My sample sparse matrix A */
>>                 11.0   0    0  14.0  0
>>                 21.0  22.0  0  24.0  0
>>                 31.0   0   33. 34.0 35.0
>>                 0      0   43. 44.0  0
>>                 0      0    0   0   55.
>>        const int sizeMat=5;    // Matrix is 5 by 5.
>>        int i,j;
>>        int nonZero=12;
>>        double val[] ={11., 14.,21., 22., 24., 31., 33., 34., 35., 43.,
>> 44., 55.};
>>        int col_ind[]={0, 3, 0, 1, 3, 0, 2, 3, 4, 2, 3, 4};
>>        int row_ptr[]={0, 2, 5, 9, 11, 12};
>>        double knB[]={2.0, 0.0, 1.0, 1.0, 2.0};
>>        double answer[]={-0.0348308, -0.152452, -0.150927, 0.170224,
>> 0.0363636};
>> // calculate row_index, vector_index and number of nonzero per row:
>>        int nZperRow[]={3,4,2,1};
>>        int row_ind[]={0,0, 1,1,1, 2,2,2,2, 3,3, 4};
>>        int vec_ind[]={0,1,2,3,4};
>>        double initX[]={9.,9.,9.,9.,9.};
>>                PetSc codes start.
>>        printf("\n*** PetSC Testing phase. ***\n");
>>        /* Create variables of PetSc */
>>        Vec            x,b,u;  /* approx solution, RHS, exact solution
>> */ /*a
>> linear system, Ax = b. */
>>        Mat            A;      /* linear system matrix */
>>        KSP            ksp;    /* linear solver context */
>>        PetscInt       Istart,Iend;     /* Index for local matrix of
>> each
>> processor */
>>        PetscInt       istart,iend;     /* Index for local vector of
>> each
>> processor */
>>        PetscViewer    viewer;
>>        PetscMPIInt    rank;
>>        PetscErrorCode ierr;
>>        PetscTruth     flg;
>>        static char help[] = "Parallel vector layout.\n\n";
>>        /* Initialization of PetSc */
>>        PetscInitialize(&argc,&args,(char*)0,help);
>>        MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
>>                Create parallel matrix, specifying only its global
>> dimensions. :
>>                When using MatCreate(), the matrix format can be
>> specified at
>>                runtime. Also, the parallel partitioning of the matrix
>> is
>>                determined by PETSc at runtime.
>>                Performance tuning note:  For problems of substantial
>> size,
>>                preallocation of matrix memory is crucial for attaining
>> good
>>                performance. See the matrix chapter of the users manual
>> for details.
>>                - Allocates memory for a sparse parallel matrix in AIJ
>> format
>>                (the default parallel PETSc format: Compressed Sparse
>> Row).
>>        ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>>        ierr =
>> MatSetSizes
>> (A,PETSC_DECIDE,PETSC_DECIDE,sizeMat,sizeMat);CHKERRQ(ierr);
>>        ierr = MatSetType(A, MATAIJ);CHKERRQ(ierr);
>>        ierr = MatSetFromOptions(A);CHKERRQ(ierr);
>>                Currently, all PETSc parallel matrix formats are
>> partitioned by
>>                contiguous chunks of rows across the processors.
>> Determine
>> which
>>                rows of the matrix are locally owned.
>>        ierr = MatGetOwnershipRange(A,&Istart,&Iend);CHKERRQ(ierr);
>>        printf(" Rank= %d, Istart_row= %d, Iend_row+1 = %d \n", rank,
>> Istart, Iend);
>>                ierr =
>> MatMPIAIJSetPreallocationCSR
>> (A,row_ptr,col_ind,PETSC_NULL);CHKERRQ(ierr)
>> // Standard format, CSR
>>                ierr =
>> MatSeqAIJSetPreallocation(A,0,nZperRow);CHKERRQ(ierr);
>> // Defining the number of nonzero for each row.
>>        ierr =
>>        ierr = MatSeqAIJSetPreallocation(A, 0,nZperRow);CHKERRQ(ierr);
>>                Set matrix elements in parallel.
>>                - Each processor needs to insert only elements that it
>> owns
>>                        locally (but any non-local elements will be
>> sent to the
>>                        appropriate processor during matrix assembly).
>>                - Always specify global rows and columns of matrix
>> entries.
>>        /* Method 1: Efficient method. */
>>        for (i=row_ptr[Istart]; i<row_ptr[Iend]; i++)
>>                //ierr =
>> MatSetValue
>> (A,row_ind[i],col_ind[i],val[i],INSERT_VALUES);CHKERRQ(ierr);
>>                ierr =
>> MatSetValues(A,1,&(row_ind[i]),
>> 1,&(col_ind[i]),&(val[i]),INSERT_VALUES);
>> CHKER
>> RQ(ierr);
>>        ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>        ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>                Visaualize a matrix. Set a viewer's style.
>>                To see a dense matrix, use the following two lines:
>>                Line1: viewer = PETSC_VIEWER_STDOUT_(PETSC_COMM_WORLD);
>>                Line2: ierr =
>> PetscViewerSetFormat(viewer,PETSC_VIEWER_ASCII_DENSE);
>>        ierr = MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>>                Create parallel vectors.
>>        ierr = VecCreate(PETSC_COMM_WORLD,&u);CHKERRQ(ierr);
>>        ierr = VecSetSizes(u,PETSC_DECIDE,sizeMat);CHKERRQ(ierr);
>>        ierr = VecSetFromOptions(u);CHKERRQ(ierr);
>>        ierr = VecDuplicate(u,&b);CHKERRQ(ierr);
>>        ierr = VecDuplicate(b,&x);CHKERRQ(ierr);
>>                PETSc parallel vectors are partitioned by
>> Determine
>>                which vector are locally owned.
>>        VecGetOwnershipRange(b,&istart,&iend);
>>                Insert vector values
>>        VecSetValues(u,sizeMat,vec_ind,answer,INSERT_VALUES);
>>        VecSetValues(x,sizeMat,vec_ind,initX,INSERT_VALUES);
>>        VecSetValues(b,sizeMat,vec_ind,knB,INSERT_VALUES);
>>                Assemble vector, using the 2-step process:
>>                VecAssemblyBegin(), VecAssemblyEnd()
>>                Computations can be done while messages are in
>> transition
>>                by placing code between these two statements.
>>        VecAssemblyBegin(u); VecAssemblyEnd(u);
>>        VecAssemblyBegin(x); VecAssemblyEnd(x);
>>        VecAssemblyBegin(b); VecAssemblyEnd(b);
>>                View the exact solution vector if desired
>>        if(rank==0) printf("Vector u: \n");
>>        flg = 1;
>>        if (flg) {ierr =
>> VecView(u,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);}
>>        if(rank==0) printf("Vector x: \n");
>>        if (flg) {ierr =
>> VecView(x,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);}
>>        if(rank==0) printf("Vector b: \n");
>>        if (flg) {ierr =
>> VecView(b,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);}
>>                Create the linear solver and set various options
>>        KSPCreate(PETSC_COMM_WORLD,&ksp);
>>        KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);
>>        KSPSetInitialGuessNonzero(ksp,PETSC_TRUE);
>>        KSPSetFromOptions(ksp);
>>                Solve the linear system
>>        KSPSolve(ksp,b,x);
>>        if(rank==0) printf("Solved Vector x: \n");
>>        if (flg) {ierr =
>>                Free work space.  All PETSc objects should be destroyed
>> when they are no longer needed.
>>        ierr = KSPDestroy(ksp);CHKERRQ(ierr);
>>        ierr = MatDestroy(A);CHKERRQ(ierr);
>>        ierr = VecDestroy(u);CHKERRQ(ierr);  ierr =
>> VecDestroy(x);CHKERRQ(ierr);
>>        ierr = VecDestroy(b);CHKERRQ(ierr);
>>        ierr = PetscFinalize();CHKERRQ(ierr);
>>        printf("\n");
>>        return 0;
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
