Build Petsc DLL's with Visual Studio C++ 2003 compiler
Thuc Bui bui at calcreek.com
Sun Oct 5 13:57:46 CDT 2008
Hi Chetan,
I was able to build Petsc-2.3.3-p15 for the Debug and Release builds using
your vcproj file albeit having to remove and/or copy several files to
different locations in the build directory tree.
When I got to the ReleaseDLL build, I had to edit several header files to
add to the function and variable declarations with PETSCMAT_DLLEXPORT,
PETSCVEC_DLLEXPORT, etc. to get the codes compiled. Unfortunately, when time
to link, the compiler wants the file petsc.def. I believe this file is the
Visual Studio DLL interface file, and it is specified in the vcproj for the
ReleaseDLL and DebugDLL configurations. By any chance do you have this file
available?
Thanks a lot for your help,
Thuc
-----Original Message-----
From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov]
On Behalf Of Thuc Bui
Sent: Friday, October 03, 2008 1:45 PM
To: petsc-users at mcs.anl.gov
Subject: RE: Build Petsc DLL's with Visual Studio C++ 2003 compiler
Thanks a lot Chetan, for taking your time to provide insightful information.
I do build Petsc without Fortran. I will let you know how it goes. Thanks
again for your help.
Thuc
On Behalf Of Chetan Jhurani
Sent: Friday, October 03, 2008 10:43 AM
> From: Thuc Bui
> Thank you Satish and Chetan very much for your answers. I will try out
> Chetan's project/solution files this weekend. Before doing so, I will need
> to re-run configure.py only once per Chetan's instruction then copy and
> rename the build directories. I will set the configuration option
> --with-shared=0. If this is incorrect, please let me know.
The options I had used are written below.  Didn't know then that
with-dynamic=1
and with-shared=1 don't work on Windows.  I was building under the
assumption of a
normal petsc build, and not for the purpose of using a visual studio project
later
on (hence the --download-f-blas-lapack).
Actually, I remember now why I made this into a separate project.  My main
exe was
using multiple libraries (including petsc). Petsc used the C multithreaded
static
run time library.  Some other one used C multithreaded dynamic run time
library.
I didn't want to play with the petsc build system on windows.  It was
extremely
slow.  I believe it took hours on my machine because process spawing is
slower. Or
perhaps the python interpreter was slow.  So I just took the src tree and
created
a vcproj out of it and used the appropriate run-time library.  Now it takes
just
4 minutes to build the full petsc tree (approx 725 object files).
I digress.  But that was a justification, and some info if you need to know
which runtime lib is being used.
If you have problems about vcproj/sln files do let me know.  I'm sure
this will be a bumpy ride and unlikely to be "official supported" either.
I forgot to mention the project contains just the C files.  No fortran
file is compiled.
The configuration options --
--with-shared=1
--with-dynamic=1
-with-clanguage=C++
-with-debugging=yes       --> Debug mode, could be changed.
--with-gnu-compilers=0
--with-cc=cl
--with-cxx=cl
--with-fc=ifort
--with-mpi=1
Chetan
> Thanks,
> Thuc
> Sent: Thursday, October 02, 2008 11:21 PM
> On Thu, 2 Oct 2008, Satish Balay wrote:
> > On Thu, 2 Oct 2008, Thuc Bui wrote:
> > > I attempt to build Petsc DLL libraries with configure.py
> using first
> with
> > > the option --with-shared=1, which is ignored as indicated in
> configure.log,
> > > and with --with-dynamic=1, which the script crashes.
> > > Is it possible to build Petsc DLL's? Does any one know
> how to do this? I
> > > would like to reduce the size of my executables since I
> have several
> using
> > > Petsc, and each of them is now huge comparing with that
> use the "old"
> > > Sparskit solver.
> > Sorry - currently we don't have a mechanism to build dlls on
> > windows. So the above options [shared and dynamic] don't work on
> > windows.
> I have created a set of visual studio project/solution files.
>  They've been
> tried with petsc-2.3.2-p7.  There are 4 configurations --
> Debug, Release,
> DebugDLL, and ReleaseDLL.  The first two create a static lib,
> and the last
> two create a DLL (one output file per config).
> This results in a petsc.dll of size 3 MB in release mode.
> Debug mode is 8.5
> MB.
> You can get them here - http://www.ices.utexas.edu/~chetan/petsc/
> Place the files in petsc-2.3.2-p7/src directory. Run petsc
> config script,
> rename the $config directories in bmake directory to appropriate name
> (Debug,
> Release, DebugDLL, ReleaseDLL).  You'll have to run petsc
> configure ONCE and
> copy directories.  Change PETSC_ARCH_NAME and PETSC_NAME in
> petscconf.h
> in each directory. Preprocessor macros like PETSC_DLL_EXPORT
> are defined
> in the vcproj file.
> Warnings:
> - I'm sure I've missed some steps that I no longer remember.
> - Not all the files in petsc/src are compiled. Most are.
> - The output (objs, libs, dlls) go into non-standard
> directories, so change
> them.
> - Some env variables, like $(MPI_DIR), are used in include/link paths.
> - blas.lib and lapack.lib are assumed to exist in link path.
> Chetan
