Using MAT_NO_NEW_NONZERO_LOCATIONS and MAT_SYMMETRIC give error
Tue May 27 12:31:44 CDT 2008
    The calling sequence for this routine changed recently, make sure
you are using the
same PETSc version on your different systems.
    Also please send bug reports like this to petsc-maint at mcs.anl.gov
not petsc-users at mcs.anl.gov
    Barry
On May 27, 2008, at 11:13 AM, Matthew Knepley wrote:
> On Tue, May 27, 2008 at 10:58 AM, Ben Tay <zonexo at gmail.com> wrote:
>> Hi,
>> I read in the manual that I can use either call
>> MatSetOption(A_mat_uv,MAT_NO_NEW_NONZERO_LOCATIONS,PETSC_TRUE,ierr)
>> or call
>> MatSetOption(A_mat,MAT_SYMMETRIC,PETSC_TRUE,ierr).
>> When I use MAT_NO_NEW_NONZERO_LOCATIONS for the matrix formed by my
>> momentum
>> eqn, I get the error on my home computer udring compiling:
>> :\Myprojects2\imb_airfoil_x2_parallel\mom_disz.f90(356) : Error:
>> This name
>> does not have a type, and must have an explicit type.
>> [MAT_NO_NEW_NONZERO_LOCATIONS]
>> call
> 1) It appears this symbol was not defined for Fortran. This is fixed
> in petsc-dev.
>> Although this error does not happen when I compile in linux, I can
>> this
>> error during run:
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or -
>> on_error_attach_debugger
>> [0]PETSC ERROR: or see
>> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal
>> [0]PETSC
>> ERROR: or try http://valgrind.org on linux or man libgmalloc on
>> Apple to
>> find memory corruption errors
>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile,
>> link, and
>> run
>> [0]PETSC ERROR: to get more information on the crash.
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Signal received!
>> [0]PETSC ERROR:
>> I use KSPRICHARDSON and PCILU for my momentum eqn matrix.
>> When I use MatSetOption(A_mat,MAT_SYMMETRIC,PETSC_TRUE,ierr) for my
>> poisson
>> eqn which is symmetric, I get the same error as above during run.
>> Btw, I'm
>> using hypre as the preconditioner and default solver.
> This option does not actually do anything. The SEGV must come from
> another error.
>  Matt
>> May I know why using these options give the error?
>> Thank you very much.
>> Regards.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
