Comparing matrices between 2 different codes and viewing of matrix
Ben Tay zonexo at gmail.com
Tue May 27 10:23:56 CDT 2008
Hi Barry,
Got it working. Thanks alot!
Barry Smith wrote:
>    You use EITHER PetscViewerCreate() and PetscViewerSetType() and
> PetscViewerFileSetName() OR PetscViewerASCIIOpen()
> so use
>> call PetscViewerASCIIOpen(MPI_COMM_WORLD, "matrix.txt",viewer,ierr)
>>> call MatView(A_mat_uv,viewer,ierr)
>> call PetscViewerDestroy(viewer,ierr)
> On May 27, 2008, at 5:57 AM, Ben Tay wrote:
>> Hi Barry,
>> Thanks for pointing out. However, I only got a 0 byte file after
>> adding the include statement.
>> I am programming in parallel and my matrix is created using
>> MatCreateMPIAIJ. Did I missed out some commands?
>> PetscViewer viewer
>> call  PetscViewerCreate(MPI_COMM_WORLD,viewer,ierr)
>> Thank you very much.
>> Regards.
>> Barry Smith wrote:
>>>   Likely you forgot to #include "finclude/petscviewer.h" in the
>>> Fortran subroutine that
>>> is doing this stuff.
>>> On May 25, 2008, at 5:43 AM, Ben Tay wrote:
>>>> Hi,
>>>> I have an old serial code and a newer parallel code. The new
>>>> parallel code is converted from the old serial code. However, due
>>>> to numerous changes, the answers from the new code now differs from
>>>> the old one after the 1st step. What is the best way to compare the
>>>> matrices from the 2 different code?
>>>> I guess the most direct mtd is to use MatView to store the matrix
>>>> in a ACSII file and spot the difference between the 2 files.
>>>> However, I can't seem to get it right. What I did is:
>>>> PetscViewer viewer
>>>> call  PetscViewerCreate(PETSC_COMM_SELF,viewer,ierr)
>>>> call PetscViewerASCIIOpen(PETSC_COMM_SELF, "matrix.txt",viewer,ierr)
>>>> However, I get the error that "PetscViewer viewer" has syntax
>>>> error. Hope you can help me out.
>>>> Regards
