Code structuring - Communicator
Tue May 27 10:23:44 CDT 2008
On Tue, May 27, 2008 at 10:18 AM,  <Amit.Itagi at seagate.com> wrote:
> Barry,
> I got a part of what I was trying to do (sub-communicator etc.), working.
> Now suppose I want to repeat a calculation with a different input, I have
> two ways of doing it (based on what I have coded).
> 1)
> MPI_Initialize
> Create a group using MPI_Comm_group
> Create several sub-groups and sub-communicators using MPI_Group_Incl and
> MPI_Comm_create
> Assign the sub-communicator to PETSC_COMM_WORLD
> // Calculation 1
> Do PetscInitialize
> Perform the calculation
> Do PetscFinalize
> // Calculation 2
> Do PetscInitialize
> Do PetscFinalize
> Do MPI_finalize
> 2)
> MPI_Initialize
> MPI_Comm_create
> Do PetscInitialize
> // Calculation 1
> // Calculation 2
> Do PetscFinalize
> Do MPI_finalize
> The first method crashes. I am trying to understand why.  The documentation
What do you mean "crashes" and what line does it happen on? You can use
-start_in_debugger to get a stack trace. I do not completely understand your
pseudocode, however, you should never call PetscInitialize()/Finalize() more
than once.
   Matt
> says that PetscFinalize calls MPI_finalize only if MPI_Initialize is not
> called before PetscInitialize. In my case, is PetscFinalize destroying the
> sub-communicators ?
> Thanks
> Rgds,
> Amit
>             Barry Smith
>             <bsmith at mcs.anl.g
>             ov>                                                        To
>             Sent by:                  petsc-users at mcs.anl.gov
>             owner-petsc-users                                          cc
>             @mcs.anl.gov
>             No Phone Info                                         Subject
>             Available                 Re: Code structuring - Communicator
>             05/09/2008 03:07
>             PM
>             Please respond to
>                  nl.gov
>    There are many ways to do this, most of them involve using MPI to
> construct subcommunicators
> for the various sub parallel tasks. You very likely want to keep
> PetscInitialize() at
> the very beginning of the program; you would not write the calls in
> terms of
> PETSC_COMM_WORLD or MPI_COMM_WORLD, rather you would use the
> subcommunicators to create the objects.
>    An alternative approach is to look at the manual page for
> PetscOpenMPMerge(), PetscOpenMPRun(),
> PetscOpenMPNew() in petsc-dev. These allow a simple master-worker
> model of parallelism
> with PETSc with a bunch of masters that can work together (instead of
> just one master) and each
> master controls a bunch of workers. The code in src/ksp/pc/impls/
> openmp uses this code.
> Note that OpenMP has NOTHING to do with OpenMP the standard. Also I
> don't really have
> any support for Fortran, I hope you use C/C++. Comments welcome. It
> sounds like this matches
> what you need. It's pretty cool,  but underdeveloped.
>    Barry
> On May 9, 2008, at 12:46 PM, Amit.Itagi at seagate.com wrote:
>> Hi,
>> I have a question about the Petsc communicator. I have a petsc program
>> "foo" which essentially runs in parallel and gives me
>> y=f(x1,x2,...), where
>> y is an output parameter and xi's are input parameters. Suppose, I
>> want to
>> run a parallel optimizer for the input parameters. I am looking at the
>> following functionality. I submit the optimizer job on 16 processors
>> (using
>> "mpiexec -np 16 progName"). The optimizer should then submit 4 runs of
>> "foo", each running parallely on 4 processors. "foo" will be written
>> as a
>> function and not as a main program in this case. How can I get this
>> functionality using Petsc ? Should PetscInitialize be called in the
>> optimizer, or in each foo run ? If PetscInitialize is called in the
>> optimizer, is there a way to make the foo function run only on a
>> subset of
>> the 16 processors ?
>> May be, I haven't done a good job of explaining my problem. Let me
>> know if
>> you need any clarifications.
>> Thanks
>> Rgds,
>> Amit
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
