Comparing matrices between 2 different codes and viewing of matrix
Sun May 25 08:55:12 CDT 2008
    Likely you forgot to #include "finclude/petscviewer.h" in the
Fortran subroutine that
is doing this stuff.
On May 25, 2008, at 5:43 AM, Ben Tay wrote:
> Hi,
> I have an old serial code and a newer parallel code. The new
> parallel code is converted from the old serial code. However, due to
> numerous changes, the answers from the new code now differs from the
> old one after the 1st step. What is the best way to compare the
> matrices from the 2 different code?
> I guess the most direct mtd is to use MatView to store the matrix in
> a ACSII file and spot the difference between the 2 files. However, I
> can't seem to get it right. What I did is:
> PetscViewer viewer
> call  PetscViewerCreate(PETSC_COMM_SELF,viewer,ierr)
> call MatView(A_mat_uv,viewer,ierr)
> call PetscViewerDestroy(viewer,ierr)
> call PetscViewerASCIIOpen(PETSC_COMM_SELF, "matrix.txt",viewer,ierr)
> However, I get the error that "PetscViewer viewer" has syntax error.
> Hope you can help me out.
> Thank you very much.
> Regards
