MatMerge_SeqsToMPI
Lisandro Dalcin dalcinl at gmail.com
Fri May 23 15:04:51 CDT 2008
On 5/23/08, Waad Subber <w_subber at yahoo.com> wrote:
> Thank you Lisandro,
> I like the idea of constructing Schur complement of Schur complement matrix.
> I will give it a try.
Mmm, I was not actually talking about a Schur complemt of a Schur
complement. In fact, I suggested that the interface nodes have to be
extended with carefully selected interior nodes. This way, all this is
equivalent to solving a problem with, let say, 1000 'logical'
subdomains, but using let say 100 processors, were the actual local
subdomains are splited to have about 10 subdomains per processor. Am I
being clear enough?
> Thanks again for the suggestions and the link
Enjoy! And please do not blame me for such a contrived code!
> Lisandro Dalcin <dalcinl at gmail.com> wrote:
>  On 5/23/08, Barry Smith wrote:
> > I notice Lapack solver for the interior
> > problem takes a lot of time compare to the iterative solver for the
> > interface, so now I am replacing the direct factorization with petsc KSP
> > solver.
> > In my experience you will want to use a KSP direct solve, for example
> > just -ksp_type preonly -pc_type lu; using an iterative solver in such
> Schur
> > complement is
> > always way to slow.
> Indeed!!
> Waad, do not do that. If your interior problem is big, the only way to
> go is to implement subdomain subpartitioning. That is, in your local
> subdomain, you have to select some DOF's and 'mark' them as
> 'interface' nodes. Then you end-up having many A_ii's at a local
> subdomain, each corresponding with a sub-subdomain... Of course,
> implementing all this logic is not trivial at all..
> My implementation of all this stuff can be found in petsc4py SVN
> repository hosted at Google Code. Here you have the (long) link:
> http://petsc4py.googlecode.com/svn/trunk/petsc/lib/ext/petsc/src/ksp/pc/impls/
> In directory 'schur' you have a version requiring MATIS matrix type
> (this is somewhat natural in the context of substructuring and finite
> elements methods). This corresponds to what Y.Sadd's book calls
> 'edge-based' partitionings.
> In directory 'schur_aij' hou have a version (never carefully tested)
> working with MATMPIAIJ matrices. This corresponds to what Y.Sadd's
> book calls 'vertex-based' partitionings (more typical to appear in
> finite difference methods).
> > > I would like very much to have a look at your implementation, and I
> think
> > that will be very useful to me.
> > > Thanks
> > > Waad
> > > Lisandro Dalcin wrote: On 5/20/08, Waad Subber wrote:
> > > > 1) How do you actually get the local Schur complements. You
> > > > explicitelly compute its entries, or do you compute it after computing
> > > > the inverse (or LU factors) of a 'local' matrix?
> > > > I construct the local Schur complement matrices after getting the
> > inversion
> > > > of A_II matrix for each subdomain.
> > > Fine,
> > > > 2) Your R_i matrix is actually a matrix? In that case, it is a trivial
> > > > restrinction operation with ones and zeros? Or R_i is actually a
> > > > VecScatter?
> > > > R_i is the restriction matrix maps the global boundary nodes to the
> > local
> > > > boundary nodes and its entries is zero and one I store it as spare
> > matrix,
> > > > so only I need to store the nonzero entries which one entry per a row
> > > I believe a VecScatter will perform much better for this task.
> > > > And finally: are you trying to apply a Krylov method over the global
> > > > Schur complement? In such a case, are you going to implement a
> > > > preconditioner for it?
> > > > Yes, that what I am trying to do
> > > Well, please let me make some comments. I've spent many days and month
> > > optimizing Schur complement iterations, and I ended giving up. I was
> > > never able to get it perform better than ASM preconditioner (iff
> > > appropriatelly used, ie. solving local problems with LU, and
> > > implementing subdomain subpartitioning the smart way, not the way
> > > currently implemented in PETSc, were subpartitioning is done by chunks
> > > of continuous rows).
> > > If you are doing research on this, I would love to know your
> > > conclusion when you get your work done. If you are doing all this just
> > > with the hope of getting better running times, well, remember my above
> > > comments but also remember that I do not consider myself a smart guy
> > > As I said before, I worked hard for implementing general Schur
> > > complement iteration. All this code is avalable in the SVN repository
> > > of petsc4py (PETSc for Python), but it could be easily stripped out
> > > for use in any PETSc-based code in C/C++. This implementation requires
> > > the use of a MATIS matrix type (there is also a separate
> > > implementation for MATMPIAIJ maatrices), I've implemented subdomain
> > > subpartitioning (using a simple recursive graph splitting procedure
> > > reusing matrix reordering routines built-in in PETSc, could be done
> > > better with METIS); when the A_ii problems are large, their LU
> > > factorization can be a real bootleneck. I've even implemented a
> > > global preconditioner operation for the interface problem, based on
> > > iterating over a 'strip' of nodes around the interface; it improves
> > > convergence and is usefull for ill-conditioned systems, but the costs
> > > are increased.
> > > If you ever want to take a look at my implemention for try to use it,
> > > or perhaps take ideas for your own implementation, let me know.
> > > > > Now having the Schur complement matrix for each subdomain, I need to
> > solve
> > > > (Sum[R_i^T*S_i*R_i])u=Sum[R_i^T*g_i],
> > > > > .. i=1.. to No. of process (subdomains) in parallel.
> > > > > For the global vector I construct one MPI vector and use VecGetArray
> > > > for
> > > > > each of the sequential vector then use VecSetValues () to add the
> > values
> > > > > into the global MPI vector. That works fine.
> > > > > However for the global schur complement matix I try the same idea by
> > > > > creating one parallel MPIAIJ matrix and using MatGetArray( ) and
> > > > > MatSetValues () in order to add the values to the global matrix.
> > > > > MatGetArray( ) gives me only the values without indices, so I don't
> > know
> > > > how
> > > > > to add these valuse to the global MPI matrix.
> > > > > Thanks agin
> > > > > Waad
> > > > > Barry Smith wrote:
> > > > > On May 20, 2008, at 3:16 PM, Waad Subber wrote:
> > > > > > Thank you Matt,
> > > > > > Any suggestion to solve the problem I am trying to tackle. I want
> to
> > > > > > solve a linear system:
> > > > > > Sum(A_i) u= Sum(f_i) , i=1.... to No. of CPUs.
> > > > > > Where A_i is a sparse sequential matrix and f_i is a sequential
> > > > > > vector. Each CPU has one matrix and one vector of the same size.
> Now
> > > > > > I want to sum up and solve the system in parallel.
> > > > > Does each A_i have nonzero entries (mostly) associated with one
> > > > > part of the matrix? Or does each process have values
> > > > > scattered all around the matrix?
> > > > > In the former case you should simply create one parallel MPIAIJ
> > > > > matrix and call MatSetValues() to put the values
> > > > > into it. We don't have any kind of support for the later case,
> perhaps
> > > > > if you describe how the matrix entries come about someone
> > > > > would have suggestions on how to proceed.
> > > > > Barry
> > > > > > Thanks again
> > > > > > Waad
> > > > > > Matthew Knepley wrote: On Tue, May 20, 2008 at
> > > > > > 2:12 PM, Waad Subber wrote:
> > > > > > > Hi,
> > > > > > > I am trying to construct a sparse parallel matrix (MPIAIJ) by
> > > > > > adding up
> > > > > > > sparse sequential matrices (SeqAIJ) from each CPU. I am using
> > > > > > > MatMerge_SeqsToMPI(MPI_Comm comm,Mat seqmat,PetscInt m,PetscInt
> > > > > > n,MatReuse
> > > > > > > scall,Mat *mpimat)
> > > > > > > to do that. However, when I compile the code I get the following
> > > > > > > undefined reference to `matmerge_seqstompi_'
> > > > > > > collect2: ld returned 1 exit status
> > > > > > > make: *** [all] Error 1
> > > > > > > Am I using this function correctly ?
> > > > > > These have no Fortran bindings right now.
> > > > > > Matt
> > > > > > > Thanks
> > > > > > > Waad
> > > > > > What most experimenters take for granted before they begin their
> > > > > > experiments is infinitely more interesting than any results to
> which
> > > > > > their experiments lead.
> > > > > > -- Norbert Wiener
> > > > Lisandro Dalcín
> > > > Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> > > > Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> > > > Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> > > > PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> > > > Tel/Fax: +54-(0)342-451.1594
> > > Lisandro Dalcín
> Lisandro Dalcín
Lisandro Dalcín
