Fwd: mixed matrix type?
Sean Dettrick sdettrick at gmail.com
Wed May 21 11:21:43 CDT 2008
I should have also mentioned that the matrix is symmetric.
Sean
Begin forwarded message:
> From: Sean Dettrick <sdettrick at gmail.com>
> Date: May 21, 2008 9:14:41 AM PDT
> To: petsc-users at mcs.anl.gov
> Subject: mixed matrix type?
> Hi,
> I have a sparse N*N matrix generated from a DA and a 5 point
> stencil, with a total of approx 5*N non-zero entries.  Now I would
> like to extend this matrix by adding a smaller M*M dense matrix to
> the bottom right hand side, i.e. so that there is a dense square in
> the bottom right hand corner of the otherwise sparse matrix.  The
> total number of new non-zero entries, M*M, is comparable to the
> total number of old entries, 5*N.  On top of this, there would be a
> small number of non-zero entries in the new upper-right and lower-
> left rectangular portions of the matrix, due to coupling of the two
> systems.  The new total matrix size (including zeroes) would be (N
> +M)*(N+M).
> Can anybody recommend a Mat type to store the new matrix?
> One possibility I was thinking of was to establish the original
> sparse Mat with a DA in a sub-communicator (with half the CPUs), and
> get the ownership range with MatGetOwnershipRange.  Then in the
> petsc_comm_world communicator, the complete matrix could be
> constructed (by element-wise copying the old one I suppose), and the
> ownership range could be maintained manually.
> Does this sound like a reasonable strategy?
> I would very much appreciate any suggestions or advice.
> Thanks,
> Sean Dettrick
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080521/d519d3c7/attachment.htm>
