How to efficiently change just the diagonal vector in a matrix at every time step
Sean Dettrick sdettrick at gmail.com
Mon May 12 05:42:47 CDT 2008
On May 10, 2008, at 10:38 AM, Ben Tay wrote:
> Hi Sean,
> Maybe for me, I can just insert vector diagonal D into the matrix A
> and call Assembly and KSP at every time step. Should that be better
> since there is no need to copy A into B?
> Thanks!
Yes, that sounds like it would be faster.  I suppose you would use
INSERT_VALUES rather than ADD_VALUES.
In my case I copy the whole matrix because constructing the time-
constant part of the diagonal is very complicated.   But now that you
mention it, I could store both the time-constant and time-varying
diagonal components in two separate Vecs, and only have one Mat, and
then do MatDiagonalSet() twice at each timestep - the first time with
INSERT_VALUES, the second with ADD_VALUES.  That sounds like it would
be faster.
Thanks to you too,
Sean
> On Fri, May 9, 2008 at 8:50 PM, Sean Dettrick <sdettrick at gmail.com>
> wrote:
> One way to do it is to have two Mats, A and B, and a Vec, D, to
> store the diagonal.  A is constructed only on the first step.  On
> subsequent steps, A is copied into B, and then D is added to the
> diagonal:
>  ierr = MatCopy( A, B, SAME_NON_ZERO_PATTERN );
>  ierr = MatDiagonalSet( B, D, ADD_VALUES );
> The KSP uses B as the matrix, not A.
> I don't know if this approach is efficient or not.  Can anybody
> comment?
> Thanks,
> Sean
> On May 9, 2008, at 2:33 PM, Ben Tay wrote:
> Hi,
> I have a matrix and I inserted all the relevant values during the
> 1st step. I'll then solve it. For the subsequent steps, I only need
> to change the diagonal vector of the matrix before solving. I wonder
> how I can do it efficiently. Of course, the RHS vector also change
> but I've not included them here.
> I set these at the 1st step:
> call
> KSPSetOperators
> (ksp_semi_x,A_semi_x,A_semi_x,SAME_NONZERO_PATTERN,ierr)
> call KSPGetPC(ksp_semi_x,pc_semi_x,ierr)
>  ksptype=KSPRICHARDSON
>  call KSPSetType(ksp_semi_x,ksptype,ierr)
>  ptype = PCILU
>  call PCSetType(pc_semi_x,ptype,ierr)
>  call KSPSetFromOptions(ksp_semi_x,ierr)
>  call KSPSetInitialGuessNonzero(ksp_semi_x,PETSC_TRUE,ierr)
>  tol=1.e-5
>  call
> KSPSetTolerances
> (ksp_semi_x
> ,tol
> ,PETSC_DEFAULT_DOUBLE_PRECISION
> ,PETSC_DEFAULT_DOUBLE_PRECISION,PETSC_DEFAULT_INTEGER,ierr)
> and what I did at the subsequent steps is:
> do II=1,total
>  call MatSetValues(A_semi_x,1,II,1,II,new_value,INSERT_VALUES,ierr)
> end do
> call MatAssemblyBegin(A_semi_x,MAT_FINAL_ASSEMBLY,ierr)
> call MatAssemblyEnd(A_semi_x,MAT_FINAL_ASSEMBLY,ierr)
> call KSPSolve(ksp_semi_x,b_rhs_semi_x,xx_semi_x,ierr)
> I realise that the answers are slightly different as compared to
> calling all the options such as KSPSetType, KSPSetFromOptions,
> KSPSetTolerances at every time step. Should that be so? Is this the
> best way?
> Also, I can let the matrix be equal at every time step by fixing the
> delta_time. However, it may give stability problems. I wonder how
> expensive is these type of value changing and assembly for a matrix?
> Thank you very much.
> Regards.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080512/13c5d22e/attachment.htm>
