Cannot use PETSC_DEFAULT in MatMatMult
Thu May 8 14:15:19 CDT 2008
     In Fortran you must use PETSC_DEFAULT_DOUBLE_PRECISION.
     I'll make sure this is may clear in the docs
    Barry
    There is also a PETSC_DEFAULT_INTEGER for Fortran
On May 8, 2008, at 1:58 PM, Waad Subber wrote:
> Hi,
> I am trying to multiply to spares matrices. I am using PETSC_DEFAULT
> for the fill ratio; however, I cannot compile the code I get the
> following error message :
> Error: master.F, line 55: This name does not have a type, and must
> have an explicit type.   [PETSC_DEFAULT]
>        call MatMatMult(A,B,MAT_REUSE_MATRIX,PETSC_DEFAULT,C,ierr)
> compilation aborted for master.F (code 1)
> Thanks
> Waad
> Be a better friend, newshound, and know-it-all with Yahoo! Mobile.
> Try it now.
