Create a pure diagonal matrix
Mon Mar 31 16:30:50 CDT 2008
Using a combination of Jacobi and KSP scaling, you almost never need a
diagonal matrix in solves. However, if you really do, I would just use
MatDiagonScale():
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatDiagonalScale.html#MatDiagonalScale
and if you really need to, you can wrap that operation in a MatShell.
   Matt
On Mon, Mar 31, 2008 at 4:11 PM, Shi Jin <jinzishuai at yahoo.com> wrote:
> Hi,
> I have a related question to the one above: what is the best way to create a
> purely diagonal matrix?
> I am using
> ierr = MatCreateMPIAIJ(comm,localM,localN,PETSC_DETERMINE,PETSC_DETERMINE,1,
> PETSC_NULL, 0, PETSC_NULL, &lumpedMP);CHKERRQ(ierr);
> But I would think there might be a even better (faster/less memory) way?
> I thought about the BDiag Matrix. I tried
> ierr=MatCreateMPIBDiag(comm,localM,globalSize,globalSize,PETSC_NULL,1,
> PETSC_NULL,PETSC_NULL,&lumpedM);CHKERRQ(ierr);
> but not sure if it is done correctly. I am a little suspicious about those
> pointers I set as NULL.
> If the above two are both correct, is there a better one?
> Thank you very much.
> Shi Jin, PhD
>  ________________________________
> Special deal for Yahoo! users & friends - No Cost. Get a month of
> Blockbuster Total Access now
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
