Mannually specify a diagonal matrix as a preconditioner?
Shi Jin jinzishuai at yahoo.com
Mon Mar 31 16:04:02 CDT 2008
Hi there,
I am trying to solve a mass matrix linear system by KSPSolve. Right now, I am passing the mass matrix itself (let's call it M) to KSPSetOperators() as the Pmat argument. In order to speed up the convergence, I have constructed the lumped mass matrix (named lumpedM). For a linear finite element, this is simply a diagonal matrix with entries equal to the sum of the row on M. It is a common practice to replace M with lumpedM to have faster convergence without losing the order of accuracy.
What I want to do is to still solve the M matrix but use lumpedM to precondition it. This way hopefully the number of iterations would be greatly reduced. In Petsc code, I tried
 ierr = KSPSetOperators( solMP, M, lumpedM, SAME_PRECONDITIONER);
However, instead of giving faster convergence, it actually takes more iterations to convergence than the regular one. Therefore, I wonder if setting lumpedM as Pmat is the correct way to do it. Could you please advice? I think right now lumpedM is taken as the input to compute the preconditioning matrix, using whatever method is specified by -pc_type . What I really want to do is to simply set lumpedM as the precondition matrix, without spending time to compute anything.
Thank you very much.
Shi
Shi Jin, PhD
      ____________________________________________________________________________________
Like movies? Here's a limited-time offer: Blockbuster Total Access for one month at no cost.
http://tc.deals.yahoo.com/tc/blockbuster/text4.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080331/9c8569a1/attachment.htm>
