Linking problems with ifort and visual studio 2003
Ben Tay zonexo at gmail.com
Sun Mar 23 21:23:40 CDT 2008
Hi Satish,
I tried to change the compiler options to be as similar to that in the
cygwin environment. Still can't manage to get it to work. The errors I
copy n paste is directly from the IDE of studio 2003, so I'm sure it
can't be from Compaq. Btw, here's the options:
For compiling (no prob)
/nologo /Zi /O3 /fpp /include:"Debug/"
/include:"E:\cygwin\codes\petsc-2.3.3-p10"
/include:"E:\cygwin\codes\petsc-2.3.3-p10\include"
/include:"E:\cygwin\codes\petsc-2.3.3-p10\bmake\win32_ifort_nodebug"
/include:"E:\cygwin\codes\petsc-2.3.3-p10\include\mpiuni"
/include:"Debug/" /extend_source:132 /real_size:64 /Qsave /iface:cvf
/module:"Debug/" /object:"Debug/" /traceback /check:bounds /c
Cygwin:
/cygdrive/e/cygwin/codes/petsc-2.3.3-p10/bin/win32fe/win32fe ifort
--nodetect -c
  -MT -O3 -QxW -fpp  -I/cygdrive/e/cygwin/codes/petsc-2.3.3-p10
-I/cygdrive/e/cy
gwin/codes/petsc-2.3.3-p10/bmake/win32_ifort_nodebug
petsc-2.3.3-p10/include
-I/cygdrive/e/cygwin/codes/petsc-2.3.3-p10/include/mpiun
i        -o ex1f.o ex1f.F
Visualstudio 2003:
For linker
/OUT:"Debug/ns2d_c.exe" /INCREMENTAL /NOLOGO
/LIBPATH:"E:\cygwin\codes\petsc-2.3.3-p10\lib\win32_ifort_nodebug"
/LIBPATH:"E:\cygwin\codes\petsc-2.3.3-p10\externalpackages\fblaslapack\win32_ifort_nodebug"
/LIBPATH:"E:\cygwin\codes\petsc-2.3.3-p10\include\mpiuni"
/LIBPATH:"C:\Program Files\Tecplot\Tec360\bin\\" /NODEFAULTLIB:"LIBCMT"
/DEBUG /PDB:"Debug/ns2d_c.pdb" /SUBSYSTEM:CONSOLE tecio.lib ws2_32.lib
kernel32.lib user32.lib gdi32.lib advapi32.lib libpetscts.lib
libpetscsnes.lib libpetscksp.lib libpetscdm.lib libpetscmat.lib
libpetscvec.lib libpetsc.lib libfblas.lib libflapack.lib libmpiuni.lib
Cygwin:
For linker
--nodetect -M
T -O3 -QxW -fpp  -o ex1f ex1f.o
-L/cygdrive/e/cygwin/codes/petsc-2.3.3-p10/lib/
win32_ifort_nodebug
-L/cygdrive/e/cygwin/codes/petsc-2.3.3-p10/lib/win32_ifort_n
odebug -lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetsc
-L/cygdrive/e/cygwi
n/codes/petsc-2.3.3-p10/lib/win32_ifort_nodebug
-2.3.3-p10/lib/win32_ifort_nodebug -lmpiuni
.3-p10/externalpackages/fblaslapack/win32_ifort_nodebug
es/petsc-2.3.3-p10/externalpackages/fblaslapack/win32_ifort_nodebug
-lflapack -L
/cygdrive/e/cygwin/codes/petsc-2.3.3-p10/externalpackages/fblaslapack/win32_ifor
t_nodebug
-L/cygdrive/e/cygwin/codes/petsc-2.3.3-p10/externalpackages/fblaslapac
k/win32_ifort_nodebug -lfblas Gdi32.lib User32.lib Advapi32.lib
Kernel32.lib Ws2
_32.lib
Did I missed out anything? I also tried to add /nodetect /MT /QxW /fpp
but visualstudio 2003 says unrecognized options.
Thank you very much
Satish Balay wrote:
> Ok - you are using VisualStudio 2003 + IntelFortran compilers to build
> PETSc. A PETSc fortran example [ex1f] compiles from 'make' but not
> from IDE?
> Then some setting in the IDE does not match the compile option. Per
> installation instructions - you should make sure you have *all*
> compiler options you see from make [when compiling ex1f] are also
> specified in the IDE settings.
>> global.obj  error LNK2019: unresolved external symbol _PETSCINITIALIZE at 12
>> referenced in function _GLOBAL_DATA_mp_ALLO_VAR
> Looks like this code is compiled by Compaq Fortran compiler - and not
> intel fortran. Can you verify?
> Satish
> On Sun, 23 Mar 2008, Ben Tay wrote:
>> Hi,
>> I've successfully compiled the library of PETSc. The examples also worked (I
>> tested ex1f). However in the IDE of visual studio 2003, I can't seem to link,
>> although compiling the individual files were fine. The errors are:
>> global.obj  error LNK2019: unresolved external symbol _MATCREATESEQAIJ at 28
>> global.obj  error LNK2019: unresolved external symbol _VECCREATESEQ at 16
>> global.obj  error LNK2019: unresolved external symbol _VECDUPLICATE at 12
>> global.obj  error LNK2019: unresolved external symbol _KSPCREATE at 12 referenced
>> global.obj  error LNK2019: unresolved external symbol _VECASSEMBLYBEGIN at 8
>> global.obj  error LNK2019: unresolved external symbol _VECASSEMBLYEND at 8
>> bc.obj  error LNK2019: unresolved external symbol _MATSETVALUES at 32 referenced
>> in function _BC_mp_BC_BIG_A_S
>> bc_impl.obj  error LNK2001: unresolved external symbol _MATSETVALUES at 32
>> set_matrix.obj  error LNK2001: unresolved external symbol _MATSETVALUES at 32
>> petsc_sub.obj  error LNK2001: unresolved external symbol _MATSETVALUES at 32
>> bc_impl.obj  error LNK2019: unresolved external symbol _VECSETVALUE at 20
>> referenced in function _BC_IMPL_mp_BC_Q_IMPL_S
>> set_matrix.obj  error LNK2001: unresolved external symbol _VECSETVALUE at 20
>> petsc_sub.obj  error LNK2001: unresolved external symbol _VECSETVALUE at 20
>> petsc_sub.obj  error LNK2019: unresolved external symbol _MATASSEMBLYBEGIN at 12
>> referenced in function _PETSC_SUB_mp_PETSC_SOLVER_MOM
>> petsc_sub.obj  error LNK2019: unresolved external symbol _MATASSEMBLYEND at 12
>> petsc_sub.obj  error LNK2019: unresolved external symbol _MATSCALE at 12
>> petsc_sub.obj  error LNK2019: unresolved external symbol _KSPSETOPERATORS at 20
>> petsc_sub.obj  error LNK2019: unresolved external symbol _KSPGETPC at 12
>> petsc_sub.obj  error LNK2019: unresolved external symbol _KSPSETTYPE at 16
>> petsc_sub.obj  error LNK2019: unresolved external symbol _PCSETTYPE at 16
>> I was using Compaq visual fortran initially and I have converted the *.dsw
>> file to the visual studio 2003 format. Of cos, I have changed the locations to
>> the new PETSc directory. May I know what's happening? Is there anything I need
>> to set or changed in studio 2003?
>> Thanks alot!
