Block-smoothers with variable block size
Thu Mar 20 14:59:17 CDT 2008
   DON"T USE GREP! Use etags
# To access the tags in EMACS, type M-x visit-tags-table and specify
# the file petsc/TAGS.
# 1) To move to where a PETSc function is defined, enter M-. and the
#     function name.
# 2) To search for a string and move to the first occurrence,
#     use M-x tags-search and the string.
#     To locate later occurrences, use M-,
   It may not be in petsc-2.3.3 you may need to use petsc-dev
http://www-unix.mcs.anl.gov/petsc/petsc-as/developers/index.html
it is in src/mat/impls/aij/seq/inode.c
    Barry
On Mar 20, 2008, at 1:52 PM, Nicolas Tardieu wrote:
> Dear Barry,
> Thank you very much for your quick answer.
> I am searching for MatRelax_Inode in PETSc src directory using grep.
> But I just can't find it! Please note I am using 2.3.3p6
> Could you please tell me where this routine is?
> Nicoals
> 2008/3/20, Barry Smith <bsmith at mcs.anl.gov>:
>     Nicolas,
>      Actually we are very close to this. Check out the routine
> MatRelax_Inode() which is for AIJ matrices.
> For the block size it uses the inode size. If your matrix has inodes
> that match the blocks you want
> then everything is there already just use the PCSOR.
>      If you do not have inodes then you can mimic the MatRelax_Inode()
> code to make a new
> routine MatPBRelax_SeqAIJ(). If you do implement this we'd love to add
> it to PETSc.
>      Please let us know if you have additional questions.
>     Barry
> On Mar 20, 2008, at 1:07 PM, Nicolas Tardieu wrote:
> > Dear PETSc experts,
> > I am currently designing a multigrid PC that needs to operate on
> > variable block size matrices. I know PETSc does not support this
> > feature.
> > So, I will do it "by hand".  Neverthless I would like to be able to
> > use some smoothers like Jacobi or SOR in their block version.
> > What is the best solution that would work both in sequential and
> > parallel?
> > - define some MATSHELL that handle variable block size
> >     -> will I be able to use in some way a block Jacobi or SOR?
> >     -> would it be possible to use CSR inside the MATSHELL and
> > manage the variable blocks.
> > - use a AIJ matrix and manage the blocks using some indirection
> > mechanism and reprogram Jacobi or SOR
> > Thank you,
> > Nicolas
