PetscViewerBinaryOpen getting stuck
Gideon Simpson GRS2103 at columbia.edu
Sat Mar 8 00:00:40 CST 2008
I have some code that wants to read in a previously binary dumped and
gzipped matrix.  The first time I run this code, it opens the file
with PetscViewerBinaryOpen, loads the data into the matrix and
processes as expected.  However, if, for some reason, I want to
execute it a second time, when it tries to open the file, it gets
stuck.  Investigating a bit, it seems to be that the first time it
runs, when it gunzips the file, it leaves the file in /tmp.  If that
file is still in this folder, it gets stuck.  If I remove it from /
tmp, the code executes without a problem, as it did the first time.
Obviously, I could avoid using zipped files.  Is this a bug (or a
feature)?  Is there an obvious way to clean up /tmp after the code
executes?
-gideon
